Dynoed my bike!
Dynoed my bike!
Postby James » Sat Nov 20, 2004 4:40 pm
I dynoed my bike today with the Termignoni pipe. I had my bike dynoed before on the same dyno with only the K&N. The dyno generally reads low, but thats insignificant as the difference between before and after the pipe is whats important.
The figures are SAE corrected and although the bike is running a little lean and needs a PCIII to tune it properly (which will mean more HP!:D ) here are the results:
Max rear wheel HP with standard pipe - 95.6 (SAE)
Max rear wheel HP with Termignoni - 101.2 (SAE)
Max rear wheel torque with standard pipe - 50.4ft-lbs
Max rear wheel torwue with Termignoni - 52.6ft-lbs
As you can see from the graph below, the Termi provides more power from 2500rpm right through to redline! The torque is also up with the Termignoni from 2500rpm and has fixed the flatspot in the torque curve at just over 7000rpm.
Im going back to get the PCIII in a couple of weeks - I'll get the dyno results and post 'em here.
BTW - this morning I had the pipe noise tested at 100db @ 5500rpm.
James
re: Dynoed my bike!
Postby Nanna10r » Sat Nov 20, 2004 4:45 pm
Wow James that just from the Pipe n filter ?, Much nicer Torque curve 8) . You'd have to happy with that mate.
Cheers Brett
Nanna10r
re: Dynoed my bike!
Postby James » Sat Nov 20, 2004 5:01 pm
well in reality, its just the pipe because the initial dyno already had the K&N installed. But yes, Im rapt! :D
James
re: Dynoed my bike!
Postby spekt-r » Sat Nov 20, 2004 9:32 pm
Nice start, from looking at the graph you could really use that PCIII, should be rocking when thats on there too.
"The road to hell is paved with good intentions" screw it then i'll just be bad.
spekt-r
re: Dynoed my bike!
Postby Aussie Ninja » Sun Nov 21, 2004 10:25 am
I bet it feels a ton better without that hole in the top end. :D
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
Aussie Ninja
re: Dynoed my bike!
Postby redzedx7r » Sun Nov 21, 2004 12:36 pm
:) sweet, pipe looks good too
life half lived is no life at all
[url]http://tinypic.com/k85zd.jpeg[/url].
01 ZX9R (Red ofcourse!)
redzedx7r
re: Dynoed my bike!
Postby kempy » Sun Nov 21, 2004 4:36 pm
Damn, for just a pipe you gotta be happy with that!
kempy
