by Kwak addict » Tue Oct 23, 2012 1:26 pm
The only Chinese brake component I'd use is a solid rear disc, just because apart from using cheap steel, they can't really fuck them up (unlike the floating wave rotors).
From (bad) experience the pads are soft & they squeal & fade when you get them hot, they are kind to your discs though... but I'd rather sacrifice some disc wear for being able to stop if I need to.
Ex T.K.A. ZXR 750 RR
ZXR 7/9 L3 Streetfighter
