Fri Feb 07, 2014 9:04 am
Hi Guys,
I was looking at upgrading my stock exhaust on my 2013 model zx10 and was wondering if anyone had any idea's of what system would give the best results for weight loss/horsepower gained out of the systems available?
also if anyone could suggest a business (sydney/wollongong area) to take the bike to for the upgrade, would be appreciated..
Thanks for any response
Nath
Mon Feb 10, 2014 9:38 am
This was the way I went. Saved heaps of weight. Fitted it myself easy.
Tue Feb 11, 2014 8:03 am
Looks awesome, is this a full system?
Does it require a tune once you bypass the cat?
Excuse my lack of knowledge..
Cheers.
Tue Feb 11, 2014 8:43 am
No it's just a slip on Austin racing is the make if it. Very nice sound and looks. I asked Rich who is the manufacturer in the uk when I purchased it if there is a need to get it tune and he said not to worry about it. Some say you do any others don't. I havnt had mine done and I've had it fitted for about 8000k now with no problems. Bike runs awesome. Very happy with it.
Tue Feb 11, 2014 8:53 am
Looks good.
Pipe looks pretty close to the OEM rear set, melted boots an issue?
Do the boyz in blue give you much grief? No cat & short pipe, looks loud.
Tue Feb 11, 2014 9:23 am
Kermit wrote:Looks good.
No never had any heat issues. It is loud but not stupid loud. I don't ride it around town at all only up in the hills around here so don't see many cops. Having said that it probably could be an issue.
Tue Feb 11, 2014 3:20 pm
Did you buy it direct from the UK? I noticed a mob here called bikes connect stock them?
And did you just discard the cat and connect it straight into the mid pipe?
Is it as simple a that?
Tue Feb 11, 2014 6:15 pm
Natsev wrote:Did you buy it direct from the UK? I noticed a mob here called bikes connect stock them?
Yes got it direct from Austin racing in the uk. Great to deal with. To fit is simple. Just remove stock can, cat box and servo cables. The new can bolts straight on to the headers and uses the mount bolt for the cat underneath. Saves a heap of weight. This one is the GP3 carbon with ultimate end cap. There is heaps of models available all very nice.
Tue Feb 11, 2014 6:48 pm
Cool, thanks for all the info..
Wed Feb 12, 2014 2:34 am
Has anyone else been told that the cat is located in the pipes before the baffle box and not in the box itself?
I spotted a post on another forum saying to de-cat the bike fully you need to disperse the material inside these pipes to get the full benefit?
Wed Feb 12, 2014 6:49 am
Why de-cat?
Just remove the boom box and away you go
Wed Feb 12, 2014 8:46 am
Natsev wrote:Has anyone else been told that the cat is located in the pipes before the baffle box and not in the box itself?
Its been discussed on here before, 08-10 10R has the CAT at the end of the header pipe, the 11+ has the CAT in the secondary collector.
Akrapovic
WARNING: Akrapovič SLIP-ON exhaust system with OPTIONAL LINK PIPE (catalytic converter removal) for Kawaski ZX-10R,
is RECOMMENDED to be used in combination with ECU fuel mapping enrichment, otherwise you risk severe engine damage.
Leo Vince
LeoVince SBK Link Pipe:
* Eliminates stock catalytic converter
There's another thread on here about the US link pipes not having the 02 sensor bung, might want to keep that in mind when purchasing.
Wed Feb 12, 2014 8:53 am
The Austin has the o2 bung.
Wed Feb 12, 2014 12:20 pm
Wattie wrote:Why de-cat?
I just assumed (prob incorrectly) that this is what you did to get the best performance..?
Wed Feb 12, 2014 5:32 pm
Natsev wrote:Wattie wrote:Why de-cat?
Cat wouldnt make a fart in the winds difference.
But its answered above anyhoo
Reckon you need that extra 1/2HP at 13000rpm?
