04 ZX10R Revs Breaking Down - Need Help
Postby Cruissy » Wed Jul 15, 2015 11:17 am
Hi Guys, I'm having a problem with the revs breaking down on my 2004 ZX10R. It's been a track bike for the last 2 years, and when I come out of a corner onto a straight and fully open up the throttle, the revs start bogging down at 8,000 RPM, taking a long time to reach 10,000 RPM and by then I'm at the end of the straight not having changed gears once. I've tried at half throttle, and slightly improves response, but the revs still bog down. It's not like a rev limiter effect, it's feels more like a poor fuelling effect.
Thinking it may be the plugs or air, I pulled them Iridiums out, adjusted the gaps and cleaned the K&N air filter. On the next track day, the problem remained the same. Can anyone help with suggestions as to what could be the problem.
04 ZX10R (Orange) - current
03 CBR1100XX Super Blackbird (Blue) - current
07 Daytona 675 (Graphite)
98 TL1000R (Blue/White)
85 XT250 (White)
97 CBR1100XX Blackbird (Black)
98 Virago 1100 (Blue)
88 CBX750 (Silver)
79 RD400 (White)
80 RX125 (Silver)
Cruissy
Re: 04 ZX10R Revs Breaking Down - Need Help
Postby RoninZX-10R » Wed Jul 15, 2015 12:22 pm
I had a similar problem a while ago that sounds like what you're going through, my fuel pump filter was partially blocked and wouldn't allow enough fuel through when holding the throttle wide open.
From what I remember you need to remove the pump from the base of the fuel tank and clean the gauze-like filter (looks like a white-ish tea bag). If you do a search over on ZX-10R.net you should be able to find a step by step guide explaining how to get it done.
RoninZX-10R
Postby Cruissy » Wed Jul 15, 2015 12:51 pm
RoninZX-10R wrote:I had a similar problem a while ago that sounds like what you're going through, my fuel pump filter was partially blocked and wouldn't allow enough fuel through when holding the throttle wide open.
Thanks Ronin, I have a workshop manual and have googled how to remove. I can give this a go.
I've also noticed that many ZX10R owners are having fuel pump problems and having to replace the pump. Is this also a likelihood, or does cleaning the filter usually resolve the issue?
85 XT250 (White)
88 CBX750 (Silver)
79 RD400 (White)
80 RX125 (Silver)
Cruissy
Postby Glen » Wed Jul 15, 2015 9:04 pm
Fuel pump was my first thought. Good luck with it.
Postby Cruissy » Thu Jul 16, 2015 9:38 am
Have any of you guys tried those ebay Chinese replacement fuel pumps? Links below.
Are they any good? Do they last? Are they noisy?
http://www.ebay.com.au/itm/New-OEM-Repl ... 25891ee5a2
http://www.ebay.com.au/itm/271878611930 ... EBIDX%3AIT
85 XT250 (White)
88 CBX750 (Silver)
79 RD400 (White)
80 RX125 (Silver)
Cruissy
Postby Pat13 » Thu Jul 16, 2015 9:45 am
I had a similar problem with my 05 zx10r.
Turned out the fuel pump had died. Replaced the fuel pump with a second hand one from a wrecker and it was as good as new.
Pat13
Postby Gosling1 » Thu Jul 16, 2015 4:59 pm
deffo fuel pump issues - MickLC had this exact problem on his Crim a few years ago. He got a replacement fuel pump from the US at about 1/4 the price that Kawasaki wanted for an OEM pump......
as far as those $50 fuel pumps from China are concerned - you get what you pay for. They are rubbish and a complete woftam.
Postby greenmeanie » Thu Jul 16, 2015 5:40 pm
Yeah definitely time for a new fuel pump. :)
Stay clear of the chinese knock off fuel pumps :lol: .
Here is an example below. You maybe able to get one cheaper somewhere else but stick to OEM.
http://www.partshark.com/oemparts/a/kaw ... /fuel-pump
Glenn
2009 ZX10R
greenmeanie
