The bore & stroke, compression ratio of both bikes are very similar and the injection is identical.
06" 636
Bore & stroke = 68 X 48mm
Compression ratio = 12.9:1
Injection = DFI with Keihin 38 mm (1.5 in) Throttle Bodies (4)
13" 636
Bore and Stroke: 67.0 x 45.1mm
Compression Ratio: 12.9.0:1
All four of the primary header pipes are interconnected on the new bike, there claiming by doing this it improves bottom end & mid range torque.
