Wattie wrote:Why bother with the tre on a 600cc track bike? Doesn't it only make a difference in low revs?
And smog plates only stop backfiring and popping... No really performance mod
MAXUMIS wrote:The tre was designed to stop the ECU from retarding the timing in the first three gear's buy telling the ECU the bike is in sixth gear all the time except for neutral.Some bikes do get a substancal power gain in the first three gears and other's don't.
Jonnymac wrote:I don't have the tre, but by the sounds of I probably don't need it as its a six and rarely below 9g.
I might look into the smog plates as it does pop a lot, although I did think the rubber pipe between had been blocked off so I would imagine that should achieve the same outcome.
I was told by stewie that the standard spring is a 9.2kg and he found with his rider he required an 11kg for him. I'm about 90kg without gear.
I might talk to the guy that just did bg suspension as he seemed to know what he spoke about I did have it fettled with by stewie at pi and he dialled out the rear tyre getting ripped up but he left the preload on the front only one turn off soft and I hit the bump stops and dropped it at Honda which obviously wasn't great.
