OK, So I have more updates on this. One of the vacuum diaphragms in the carbs had a small tear in it, so I replaced both of those. She then sounded like she wanted to kick over, but didnt have the battery power to do it.
So I went and got the battery charged up today, and still wouldn't start. So i remembered what got it starting previously; disconnecting the choke cable from the carbies.
Well hell it worked.
Although still had the same symptoms: Throttle response = disastrous: i could have the throttle 100% open and it would take a few seconds for her to roar, pumping the throttle open and closed would barely respond. And it was still a bit of a challenge to start her.
A new problem has now arisen, with petrol leaking from what looks like from one of the float bowls (clean fuel mind you) not really bothering me at this point; an easy fix.
I took the fuel line out of the tank and let all the fuel gush out of the carbies, and there was A LOT, and still more came out of the drains when i opened them, so I'm guessing the fuel height is now out of whack.
So i'm pretty sure that carbies is DEFINETLY the problem now. but what should I do? take them to a mechanic to get new needle/seat/sync/fuel heigh done etc? or just buy some good carbs from a wreckers?
Some advice on how to proceed would be much appreciated.
