ZRX rear wavy disc?
ZRX rear wavy disc?
Postby kawadave » Mon May 28, 2012 8:03 pm
Fitted a pair of S3 Performance front wavy disc rotors to the rex.... :D
Now S3 Performance tell me that a rear matching disc is not available for this model... :?
It looks a bit gay and would like to get a matching rear.
Any information as to where I might find one would be appreciated.
2013 Motogp tipping champ.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
kawadave
Re: ZRX rear wavy disc?
Postby Gosling1 » Mon May 28, 2012 8:16 pm
Try Rated R parts mate - he has some good wavy discs. The pattern may not be identical to the S3 discs though ?
Postby Phil » Mon May 28, 2012 8:22 pm
or one of our new members Kwik, he is a Galfer dealer ;)
Postby kawadave » Mon May 28, 2012 8:43 pm
Thanks Gos and Phil...would any other kwaka share the same rear disc perhaps?
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
kawadave
Postby Whickle » Mon May 28, 2012 8:52 pm
Does the ZX9R rear disc match the rear wheel for the ZRX?
Whickle
Postby Gosling1 » Mon May 28, 2012 8:55 pm
the easiest way to check, is go onto one of the brake manufacturers and check compatibility between models. I know that the ZX1100 1983/4 front disc rotors were used on all sorts of Kawasaki models from 1983 right through to 2008 ! Although the capacity did vary a lot. It pays to check the entire range of road bikes.
Users browsing this forum: No registered users and 1 guest
