Hi Guys, New Member from QLD & Track Bike Build Photos.
Postby AjR1 » Mon Oct 08, 2012 8:36 pm
Hi peeps.
Adam here from Sunny QLD
Been riding bikes for a few years on and off. Started with a RS250 and an 08 R6
Have had a few dirt bikes over the years aswell.
Currently ride an 06 R1 as my daily and recently bought a 98 ZX6R track bike which I have been rebuilding over the past few months.
Will throw up a few pics and a bit of a story for you all.
AjR1
Re: Hi Guys, New Member from QLD
Postby kawadave » Mon Oct 08, 2012 8:48 pm
Welcome Adam....we luv pics... ;)
2013 Motogp tipping champ.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
kawadave
Postby AjR1 » Mon Oct 08, 2012 8:58 pm
Thanks for the Welcome Dave :kuda:
Funny enough me an a few other guys are doing an overnighter upto Bundy next month. Might have to say g'day and have a drink or 2.
Well here are some pics as promised.
The RS250 on the day I picked it up
A couple of weeks later
My 08 R6
Carbon Screen
LOR Carbon Exhaust
PC3
My Young Fella and his first bike
My Daily Ride
AjR1
Postby AjR1 » Mon Oct 08, 2012 9:01 pm
Ok Now its Rebuild Time.
Well I decided to by myself a dedicated track bike. And have been progressively sorting it out over the last few week.
Its old, a bit tardy looking but mechanially all good from what I can see. Will know more once I get it home and start stripping it down for a once over.
Will be replacing the race glass with new model plastics to change the look eventually but for now it will just get a freshen up.
How it looked in the ad.
All loaded up ready to go home.
AjR1
Postby AjR1 » Mon Oct 08, 2012 9:02 pm
First things first I'll be stripping off all the glass and Tank. Some fresh juice, Plugs, Filters, Oil, Coolant, lube up all the pivot points, cables etc, Wheels off , swinger and subframe off, prep and paint the frame/swinger, and then start preping the glass for paint while I wait for items that need replacing to arrive.
And decide on my temporary colour scheme.
Bikes home and ready for the strip down.
AjR1
Postby AjR1 » Mon Oct 08, 2012 9:03 pm
High as a kite on paint fumes and the frame is all painted. Now just gotta let it all dry.
Well after getting around to removing the braking system.
I found that the rear caliper was seizing up.
So after pulling it all down.
There is a bit of corrosion going on.
Since I will be overhauling the rear I may as well do the fronts aswell, So its time to order some caliper kits and clean these up & paint while im waiting for them to arrive.
Well I finished off the Pair Valve mod. So only fresh air into the motor from now on.
Also changed out the plugs as well today.
Gave the frame & swinger its 6th and final coat.
Plus all the other little bits aswell.
And also rotated the bottom shock mount 180deg so the adjuster is not blocked by the exhaust
AjR1
Postby AjR1 » Mon Oct 08, 2012 9:04 pm
The exhaust had some rash damge so decided to turn it into a shorty.
Next step Cermaic coat black
Bought a few things for the Trackie today
Tinted DB Screen
Clear SS Lines F&R
Black Fuel Cap
Green levers but with orange adjusters
Rearsets
Rear Cowl Decal
Frame Sliders
Header Gaskets
Fork Adjusters
Tank Decal - But in Black
Various Michelin Decals for front fender etc...
Upper Ninja Decals
Black Oil Cap
Rear Caliper Kit
Rim Stickers to replace the current blue ones.
Various Sponsor stickers for the belly pan etc...
Slowly Starting to go back together. Kinda looks like a bike.
Filling in the holes in the exhaust where the badge was rivited. Will fill it up again one set and then sand it back ready for more paint
Base coat on the race glass all done. Now just have to let it cure for the week before taping it up and doing the top colours.
Since the glass is going to be replaced later on it was just a quick job, The tank on the other hand will not be replaced and I'm taking a bit more care with the prep and finish on this one. All sprayed up with primer filler. Couple more coats to go and then ready for a light sand and paint.
Rear caliper all cleaned up and painted. Excuse the white paint dust. Will wash right off with the first bath once its all back together.
I have got the base coat down on the tank. 7 coats in total and still one more to go. Then its curing time for a week before taping it up for the top coat colour.
Here's a few pics of my pressure pack handy work. :topstuff:
And a couple of close up shots.
AjR1
Well I decided I'm to impatient to wait so taped up the tank and layed the first guide coat of colour.
Well the tanks almost done.
Close up (Not to shaby for a rattle can)
Rear cowl where my young fella dragged it along the concrete.
All taped up ready for the green.
Did someone say "Sexy Tank"
Well I started to paint up the tail. Had to change the layout of colour slightly due to the damage my young fella did to the white paint. So just covered up the good and painted over the bad areas.
AjR1
Postby AjR1 » Mon Oct 08, 2012 9:05 pm
First up with the green.
Well 2nd stage of the rear cowl all done. Just have to wait for it to cure and then time to tape it up again and paint the top orange.
The green actually looks nicer than I thought it would based on the colour of the cap.
Well made a little progress today.
Got the rear cowl finished off and clear coated,
along with the tank and installed the new filler cap.
Upper &Lower's painted up with the green, just have to tape it off again tomorrow and finish off the orange, touch up the white where my young fella scratched it up and clear coat it all.
Front fender all painted up and clear coated
AjR1
Tomorrow I'll be Installing the levers, rearsets, fork adjusters and work out how I'm going to get the front off the ground to remove the wheel so I can paint up the forks & front wheel. Stick the tank pad on and get the rear end of the bike reasembled atleast.
Should be a busy day at this stage.
Well a bit more done this arvo.
Left rearset installed.
Fork Adjusters Installed
Oil Cap Installed
Rear Brake Master Painted Up. Just waiting for it to dry and then I can assemble the Right Rearset
New Levers
Clutch side installed
Brake side on the master.
Well I did a little more tonight and will be back out in the garage shortly once everyone is asleep so I can work undisturbed.
Removed the blue rim tape and installed the new decals
Looks the part now.
Installed the rear wheel again and adjusted the chain (excuse all the dust and mess, My apprentice was off today)
Brake Caliper Bracket all painted up.
Rear cowl & Seat mocked up before final install.
From another angle with the new decal
Well its time for bed. So this is the last update for this week.
Pretty happy with the progress so far.
AjR1
Tank is completely finished. Decals & Tank Pad on.
Upper is all painted up, Just need to let it cure then its time for a rub back and clear coat.
Lower is all finished and belly pan decals applied.
AjR1
Postby AjR1 » Mon Oct 08, 2012 9:08 pm
Ok so do we all remember the Before Photo??? :lol:
BEFORE :shock: :shock: :oops: :oops: :shock: :shock:
FINAL PRODUCT :kuda: :kuda: :kuda: 8) 8) 8) :kuda: :kuda: :kuda:
AjR1
Re: Hi Guys, New Member from QLD & Track Bike Build Photos.
Postby laidback » Mon Oct 08, 2012 9:30 pm
Welcome Adam...Great work mate with the build and well documented. :kuda:
Postby Maddog » Mon Oct 08, 2012 11:30 pm
laidback wrote:Welcome Adam...Great work mate with the build and well documented. :kuda:
+1 :kuda:
Maddog
Postby badruss » Tue Oct 09, 2012 7:01 am
Great job, the bike looks great. And welcome :kuda:
badruss
Next
Return to Introductions and Newbie Zone
cron
