Forum rules
Post a reply
Bad Vibes
Sun Oct 30, 2011 2:39 pm
I know parallel twins vibrate somewhat but i think mine has gotten a little worse than earlier, anywhere between 3500 5000 rpm its probably at its worst, i did have a thought of changing the front sprocket a tooth or two so the rev range differs at the nominal speeds, any thoughts on this? :roll:
Re: Bad Vibes
Sun Oct 30, 2011 5:06 pm
all twins vibrate, harleys, triumphs, and er6
check to see of the engine mounts are still tight as you do a general tightness check (should do this regularly with a twin anyway!)
my er6 still doesnt vibrate as bad as my mates xs650 yammy, it shakes it mirrors and caliper bolts loose!
Re: Bad Vibes
Mon Oct 31, 2011 11:55 am
whoa maybe mines not so bad after all, i can see quite clearly from mirrors and nothings loosened or fallen off yet
Thanx Jon
Re: Bad Vibes
Sat Nov 12, 2011 7:17 pm
mine also vibrates a bit. sometimes worse than others. when it was newer it was worst around 4000 rpm. If you're near ferntree gully, Brett at Madbiker can tune mine to be pretty smooth. if you're running 91 octane try a tank of 95.
Re: Bad Vibes
Wed Dec 07, 2011 9:45 pm
yea mine vibrates a bit if i was a girl i might like it lol
i tend to just tune it out and just rev it more
Re: Bad Vibes
Wed Dec 07, 2011 11:39 pm
Mine vibrate a bit.......
at least they did until the doc chopped one off :cry:
Re: Bad Vibes
Thu Dec 08, 2011 6:31 am
mine only used to vibrate in the mornings
i discovered it was because i park with it outside @ work, the hot days warmed the fairings up, thightening the gaps - instant no vibe
i about to go to clark rubber and get some hidensity foam striping and plug the wobbly fairing gaps and see if that has any effect.
Post a reply
