javaman wrote:It forces me to ride with good 'discipline' and not throw it around recklessly like on a nimble ZX6R.
Strika wrote:
But we would ride the feckin things until they were bucking and kicking and wobbling all over the place. The frames would flex, as would the forks and swingarm. It was a fairly wobbly old piece of kit to go fast on. But go fast we did.
Maybe I am just getting older, or maybe it's the speeds at which modern bikes start to get wobbly like that, But I am finding less and less opportunities on the road to get anywhere near making my 9 start to get wiggly! And even on the track once they start getting like that I start toning things down to a more managable level!
Gosling1 wrote:the old GPz900's should sing through to 9-10k without too many issues? May need valve clearances done and a carb balance - that always makes then run better. Also - if the cam-chain is the OEM one - changing that and fitting a manual CCT can often get the engine working a lot crisper
bonester wrote:Gosling1 wrote:the old GPz900's should sing through to 9-10k without too many issues? May need valve clearances done and a carb balance - that always makes then run better. Also - if the cam-chain is the OEM one - changing that and fitting a manual CCT can often get the engine working a lot crisper
Are you saying don't buy another OEM chain? Mine has the original chain at 168000km AFAIK. Changed the tensioner for a KLR650 (IIRC) one in 1998.
Users browsing this forum: No registered users and 21 guests
