Slipping clutch -gpx750
Postby glinno » Mon Feb 09, 2015 1:40 pm
Hi guys.
I posted this question in the 'retro /resto' section but perhaps there are not many of these bikes still around these days.
Anyway, my problem is a slipping clutch. I know there are many reasons why this could be the case so trying to narrow it down a bit.
I have been rebuilding the bike for a while so I don't know if the clutch was slipping previously.
The hydraulic clutch oil has been changed.
The clutch seems to work well when cold but then slips when warm. The warmer the engine the worse the clutch slip.
Any ideas? Thanks
Glynn
FEAR. . .THE THIEF OF DREAMS
glinno
Bike: GPx750
Re: Slipping clutch -gpx750
Postby MadKaw » Mon Feb 09, 2015 1:52 pm
You could try heavier springs like Barnett, Goodridge or EBC. There pretty cheap.
Postby Smitty » Mon Feb 09, 2015 2:47 pm
MadKaw wrote:You could try heavier springs like Barnett, Goodridge or EBC. There pretty cheap.
... with Dave as it sounds like the springs get 'soft' when warm
Postby glinno » Mon Feb 09, 2015 10:10 pm
Hmm. Soft springs? Why would they get soft when they get hot? Is that normal?
I admit anything is possible with this bike though.
glinno
Bike: GPx750
Postby Gosling1 » Tue Feb 10, 2015 4:40 pm
its not the springs getting soft when hot mate, that is just a function of the oil warming up and allowing more slip from worn friction plates in your clutch - stronger springs can help overcome this if the friction plates are not too badly worn.
Best bet by far is to replace the clutch springs like Madkaw has said, and also fit a new set of friction plates as a minimum. While the clutch is apart you can spec the steel plates for correct thickness and any signs of slip (blueing). If the steel plates are worn below minimum specs, replace these as well.
Postby glinno » Tue Feb 10, 2015 11:28 pm
Ah, I see now. thanks guys. I think oil change, springs and friction plates are the go then.
glinno
Bike: GPx750
Return to General Discussion
Users browsing this forum: No registered users and 28 guests
