98ninja wrote:To revive an old thread
http://www.ebay.com.au/itm/Arrow-Clubma ... 2ebddcabf3
Laidback, what do you think of it?
98ninja wrote:Another revival.......
How many hours do you get out of the clubman engines before they need a rebuild?
Im looking at a kart with 20 hours use on the engine. Its racing use as well if that makes any difference.
98ninja wrote:A few things to note
1. Man these things have some grip
2. They oversteer through weight distribution AND through too much throttle
3. They go where you point them
4. 20 psi off track means 30 psi on track when its 35 degree air temp.
Great fun
philbo wrote:98ninja wrote:A few things to note
Great fun
you got that much of a tyre pressure change? the rule of thumb when i was racing was you should only see a 2-3 psi change
yep they are awesome fun with the grip, just need to learn to be smooth but i prefered sliding everywhere, so was harsh on the steering,
never got the chance to drive a rotax always wanted to race em but funds didnt allow.
if you go out in the wet to get extra grip lean your body weight over the opposite wheel so if your turning left lean your weight over the front left wheel, its what you do on slicks in the wet
Users browsing this forum: No registered users and 13 guests
