6maniac wrote:Memo to Gos ... power tools are not required to de-frost a fridge .......
h.b.bear wrote:6maniac wrote:Memo to Gos ... power tools are not required to de-frost a fridge .......
probably used one of those electric heated dildos
laidback wrote:Solder it...fuck that just pop rivet a bit of checker plate over it mate...
sunshine wrote:eerrr ...have you checked the price of refrigerant of late ......
hmmm ............ i reckon it should only cost ya an arm and a right knacka
thanks to julia and carbon taxes
Jonnymac wrote:Hey Gos I'm assuming your referring to putting a hole in the evaporator.
The big question is where is the hole?
I'm hoping for your sake its in the copper not an aluminum part of the coil. If its in copper it's all good. The copper hole simply needs to be soldered up. You need to use minimum of 12% silver if your thinking of doing it yourself.
System then needs to be evacuated and then recharged.
A fridge that old will be running on R12 so unless you find someone with some it will need to be retrofitted to a new refrigerant.
Oh and yer I'm a fridgy......
Users browsing this forum: No registered users and 16 guests
