Help i'm all messed up
greenmeanie
Kishy
Question..
When youre in that situation, anything instinctively an experienced
rider does that can help get you out of that situation?
Are you supposed to keep throttle on? off?
or is the only possible saviour the positioning of front wheel?
& this situation dosent necessarily have to be on a track.. also talking
about when/if it happens to anyone on the road.
blackninja
Kishy wrote:Question..
ummm open your eyes really really wide
03 zx6r blackninja
回転日本語私は実際にそう考える
回転日本語私は実際にそう考える
stevew_zzr
Whenever I've spun the rear up, the bike has corrected it all by itself...anything I try to do like back off just leads toward a highside. Luckily I haven't had one yet, but I've been bloody close. The cause was not being smooth with the throttle on cold tyres and then chopping it off when the slide started.Kishy wrote:Question..
Having said that I still reckon that guy is toast! Gotta love the Sultan of Slide though...
- mccoy.gif (519.49 KiB) Viewed 825 times
Direct from Keith Code as well as I can remember
(someone go and get twist of the wrist or Steve Brouggy quick!!)
Dont do ANYTHING, keep the throttle CONSTANT
Any acceleration (spin more) or deceleration (grip and highside) will make it worse. If you have done either and got out of it you were putting in other inputs that did it (Keith Code here, not me).
Ditto with any body inputs (remember only one force at a time)
If it all works out right the road will gradually "catch up with the tyre" and you can move onto looking for the dunnies....
If you imagine doing the same thing (ie gas it up and spinning the rear) on the straight ahead and suddenly buttoning off or moving your weight, the reaction is the same just not so "radical", ie. wieght transfer, and this is a BIG no no....
Personal experience, ZX7R, Norwell (Holden Driver Training, near Beenleigh Qld). Pulling nice slides out of 2nd gear left hander. Get cocky and apply throttle for more "angle", BIG slide, throttle off, grip Yeehaaa Buckeroo...
Now on the 12, gas it up (so to speak) and wait for the road to catch up to the tyre. This ISNT skill it is just power understand and with the bike relatively upright (thought still on a good angle) and basically showing off
I am NO Stauffer ("Its not a throttle its a light switch"
) but once you have set your throttle input you have to "ride it out" , you really have little choice other than body input to try and keep it all rubber side down.
I am sure there a lot with a HELL of a lot more experience on this important topic (with todays HP's) and I am sure willing to learn....
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
mate ive had it happen on the track, but not to that extent..i stayed on the gas, and waited for it to sort itself out..which it did...Kishy wrote:Question..
backing off could cause instant grip & high side ya...powering up will cause it to slip more...
u could always just start praying for forgiveness too..that helps...
