DYNO CHARTS - ALL MAKES AND MODELS WANTED
- MadKaw
- Administrator
heres an early one of my 98 zx9..
This was before the engine rebuild and the BMC race filter..
I believe it was 149 hp on the last dyno run...
- dyno2.JPG (47.76 KiB) Viewed 2977 times
its more important how much blank paper there is under the line than the peak. Note how Blues line is straight too (although this is HP), this is the "linear" power they talk about, the connection between throttle and motor. The space under the graph comment is more to do with the torque graph. I posted as it looks like ozzx12r is down. You will note compared to Blues there is a dip before a surge at about 10 and a half which corresponds to a mono just before the limiterStereo wrote:I am surprised by that TLR dyno..... The ZX6R only makes marginally less.... wow.....
Also note the torque a 12 has at 5000rpm (60+ ft/lb)
You can also see the reason, the hole between 4 and 5, that sent me to the dyno in the first place.
- two.jpg (73.75 KiB) Viewed 2959 times
- one.jpg (63.21 KiB) Viewed 2959 times
- ross79
I thought you said it made a little less the second time you had it dynoed??blue12 wrote:Thanks smitty.. and yes it has been redynoed but i cant find the dyno sheet..Smitty wrote:I am reposting Blue12s previous post
his will blow ya's all away...
and if I remember correctly its been back on the dyno since
...for another 8hp
SOLD 2000 ZX12R .
Heres mine 2006 ZX12 2700 miles
Full Akra Titanium Evo
Stock Filters
Power Commander PC3 USB
Custom Map
Figures hard too see but 181.8 bhp and 100.3 ftlbs torque
Note the bike made 179 bhp with standard map and the Akra, however bike was transformed with the custom map done by DSD here in the UK
From all the ZX12 dyno readings I have seen on the web I have concluded they make more BHP with stock filters.
Stock Filters
Custom Map
- dyno1.jpg (96.97 KiB) Viewed 2944 times
from what i remember my zx7r had a few more horse power than the tlr.Duane wrote:Different type of power though mate!!Stereo wrote:I am surprised by that TLR dyno..... The ZX6R only makes marginally less.... wow.....
Shitloads of torque
but like duane said, it a different style of power
