Bike wont Start, Kawasaki ZXR750
OK if you have got the pump running, it should run wether its connected to the carbies or not..........I am not sure what the go is with that problem, it sounds a bit strange....
If it was only a light kink, that wouldn't make much difference - if it was *fully* kinked like 90deg or thereabouts, then yes that would stop fuel flow.
You need to get the manual for your bike to dig any deeper into the fuelling problems, hopefully a ZX9 owner will jump on here soon with the answer to your problems........
Bionic
Re: Bike wont Start, Kawasaki ZXR750
Post by Bionic »
Hey Did you end up finding what was causing your issue?
Specwarop
Post by Specwarop »
Now its sparking and fueling but no starting.
