The only two i use are BP Ultimate and Synergy 8000.
seem to be the best so far.
Vortex 98
re: Vortex 98
Re: re: Vortex 98
ok... will shed some light on this subject for those interested. As you might be aware, Motorcycles run very high compression ratio. The normal cycle of the engine is the fuel/air mix be ignited at the ignition stroke. What happens when you run a lower octane level fuel, is it has a lower temperature and compression tolorance and causes the fuel to self ignite (commonly known as pinging) and can destroy engines, esp pistions. By running the higher octane as recommended, this problem is avoided. Its not so much for extra performance than it is to keep the engine from self destructing.mfzx6r wrote:Dan
I have put ULP in mine when they had no Prem ULP so mixed it with what was in the tank.
As for Vortex 98, there are no cleaning agents like in optimax that cause the issues with motorcycle engines. It isnt the fuel as such, i believe its the cleaning agent in optimax that causes trouble.
Kieran (10R)
Quiet they're sleeping.
2007 YZF-1000 R1
2003 BA XR8
2004 ZX 10R is Gone
2002 ZX 6R 636 (is Gone)
2007 YZF-1000 R1
2003 BA XR8
2004 ZX 10R is Gone
re: Vortex 98
I ran the local vortex religously in the 250 without a problem,I belive there was a issue with the optimax if your injection system doesnt contain a oxygen senser and i was also told it will eat out alloy over time in much the same way as ethonol.
gizmo
re: Vortex 98
You just need to rejet for Optimax!! I ran Optimax in my ZX2C without jetting & it ran abit rough, but after leaning out the mains it ran fine, maybe a little off down low but was too lazy to lean out the pilot jets.
My 636 runs fine on Optimax with Ti Akra & std map PCIIIusb.
Just yesterday loaded Internet Power Commander Micron slip on map into PCIII & will see if it runs fine on Optimax with that!!
signed
"GIZMO THE CREEKY"
