Vista caches almost all your available RAM for use, it releases as necessary for programs etc.
Sure it likes fast hardware, it's actually better at memory management than XP.
Help with New Laptop info??
- daffy67
Re: Help with New Laptop info??
Blue '07 ZX-10
- Burky
Thats good to know, some hate Vista but then others say it's greatdaffy67 wrote:Vista caches almost all your available RAM for use, it releases as necessary for programs etc.
The i used was Windows Me, Fark what a nightmare. When it worked it was ok then it would crash
What is the deal with the data key and Vista?? I was told that you can use a data key to boost the Ram with Vista
- daffy67
You can use thumb drives, even SD cards and the like and it's called ReadyBoost.Burky wrote:Thats good to know, some hate Vista but then others say it's greatdaffy67 wrote:Vista caches almost all your available RAM for use, it releases as necessary for programs etc.
Sure it likes fast hardware, it's actually better at memory management than XP.![]()
The i used was Windows Me, Fark what a nightmare. When it worked it was ok then it would crashXP fixed that
No free lunch however, some drives will work, some wont.
Why?-various reasons, some makers are testing their products and marketing them as 'readyboost' enabled/compatible-now they get to charge more $$.
Testing has shown (and it's NOT conclusive) but is logical that systems with not much RAM (say 512MB) will benefit from ReadyBoost.
As most will know when you run out of RAM the page file on your HDD is used, with a ReadyBoost drive installed this will now get used before/in addition to the page file. The HDD is the slowest part as it relies on mechanics to do it's work.
Blue '07 ZX-10
