CRIM quick action throttle
Jeebz10R
Re: CRIM quick action throttle
Post by Jeebz10R »
I should be cutting up a few conduit pieces this weekend whilst adjusting the forks of the 10.
Anyone who wants some just let me know before Friday arvo. I can drop it round if I'm in the area
*you lazy bastages! haha*
Jeebz10R
Post by Jeebz10R »
FARK! Well the conduit piece was too small in diameter. Was going to buy but a mate had some at grey conduit at home which looked like the same size as the ones Bunnings. I'lll take the housing down and get the correct size.
:oops:
the conduit size is smaller than the housing size - it has to be, as it relies only on friction to keep it secured....
the 'C'-shaped piece has to 'snap' over the stock housing, so it does have a smaller diameter .....I'll check the orange conduit I used and get the exact diameter ...
dave#3
Post by dave#3 »
I made one of these on Sunday for Cath's tracky and I'm pretty happy with the result. I got a "joiner" piece of conduit for $1.30 which should be enough material to make about 4 of these. Thanks Gos.
http://www.oz4x4.net/gallery2
no worries mate - a joiner piece is ideal, good thinking. The diameter is about 18-20mm or thereabouts ?
Jeebz10R
Post by Jeebz10R »
FARK
I finally source the right diameter conduit, bought two of the joiner piece. I dont have a bloody sharp chisel to wack the two tabs out yet. Doing a "how to" and is turning out to be more of a how not to haha
Action keeps sticking. Will have to go to bunnings to get a chisel.
DAMN YOU late night!
ZX-10R_04
State: Tasmania
Post by ZX-10R_04 »
A dremel works better :lol: thats how i got the tabs outta mine
04 ZX10R & 08 ZX10R
ZX-10R_04 wrote:A dremel works better :lol: thats how i got the tabs outta mine
Dremel is cheap in bunnings and does the job nice and quick
Jeebz10R
Post by Jeebz10R »
I thought as much so I use the dremel! I ended up with a polished look. :oops:
Thats right... laugh away... go on...
What extention piece did you guys use? Is there a specific attachment that makes it piss easy to remove metal?
Just, DO IT ! DO IT NOW !!
did mine last week with Dave's dremel. I think it was the little diamond cut bit. Takes a while though
a Dremel will do the job, as long as you use the right cutting tip. I reckon setting it all up is a pain in the arse, when a short sharp blow with a 5mm-wide fine chisel will do the same job in about .5 seconds ! :lol: .....but thats just me. I am an impatient prick .
Jeebz10R
Post by Jeebz10R »
Well seeing as though I have very little patience (and procrastinate a whole heap) I chose the chisel option
Sorry to dig up an old thread
Do you need to place a little glue on throttle sleeve or its fine to leave clipped on?
You sure do need to loosen the throttle cable play...
If you cut a small v into each end of the tube it will fit neatly into the holes in each end of the throttle area your fitting it to, so glue shouldn' t be neceassary.
If its a bit loose, I'd glue it...
And yep, I had to remove the adjuster nut on my cables to get an extra couple of mm, and its still pretty tight.. :twisted:
for some reason the Crims seem to be a bit tighter than the Barges with this mod ??
plus its a right pain in the arse to get to one of the adjusters on the Crim as it is tucked up under the f'n tank !! :x
all worth it in the end though....
