Removing a front sprocket....
Re: Removing a front sprocket....
Gosling1 wrote:I tried a 250psi rattle gun on Mel's sprocket - all it did was round out a 32mm 6-side socket !!
The only thing that will move this sprocket is heat.
Gos
you know u should use the hardened 'impact' style sockets on a rattle gun
ordinary ones can split or splinter...and act like shrapnel
not nice
Smitty wrote:......you know u should use the hardened 'impact' style sockets on a rattle gun.....ordinary ones can split or splinter...and act like shrapnel
not nice
yep - used that style. It rounded off !!
The only real problem with using heat is making sure its done in short, sharp goes - otherwise you run the risk of melting the output shaft oil-seal clean out of the cases !! :lol:
The guys at the shop told me it was the first time they had to use heat 'twice' to get that F#$#@#@@#n sprocket off !!! It was a right prick.....
hopefully Stereo's won't be as bad...
Done, dusted, just spun straight off in 1 blast of the rattle gun. Gotta lurve technology and air tools 8)
the kid
Post by the kid »
About time :roll:
I gotta get me one of those compressors........ kickass.
Loving the new front sprocket on there, loverly
