indicator fast flashing
MrWasabi
Re: indicator fast flashing
Post by MrWasabi »
seriously, buy a couple of resistors and throw them in between the indicator and where they connect to on the loom.
they should cost you no more than $3 on parts 20c on solder and 10 minutes of your time.
thats if you know something about electronics
Mistakes:
dave#3
Post by dave#3 »
I can vouch for the flasher Rossi recommended - Repco had them for about $15 and they worked for both my 03 zx9r and Cath's 06 zx6r. On the 6 it was a straight plug-in, on the 9 I had to solder a wire to the flasher, but both work perfectly.
http://www.oz4x4.net/gallery2
SoundGuy
Post by SoundGuy »
i like the fast blinking ;)
i noticed that on the oxley run :?
SoundGuy
Post by SoundGuy »
Six Addict wrote:i noticed that on the oxley run :?
Exactly.. You noticed ;)
touche fred
Saki
Post by Saki »
well i can only assume that hte Z1000 03 would have some sort of hybrid zx9 style wiring and perhaps 03 636 also, more so the 636 as it's of same gen, so guess if it works for them should work for mine!
What are they called though ? I want to sound a little smarter going into these shops than just "OH need one of them little things to stop the flashing faster!! " haha :D
dave#3
Post by dave#3 »
Saki wrote:well i can only assume that hte Z1000 03 would have some sort of hybrid zx9 style wiring and perhaps 03 636 also, more so the 636 as it's of same gen, so guess if it works for them should work for mine!
Quote the part # - it's an electronic flasher unit.
Saki
Post by Saki »
alright sweet as, cheers Dave
ezzazrx
Post by ezzazrx »
Just put smaller blinkers on the REX, the,re flashing too fast also so I bought a relay from http://www.customled.com Plugs
straight in and can be used with LED,S .
P.S. this is compatable for a Z1000. unplug the old plug in the new Cheers EZZA.
