Slip Slidin Away .... ZX7R
Kwakka Kilt
Re: Slip Slidin Away .... ZX7R
Post by Kwakka Kilt »
zx7r boy wrote:mine still alive and kicking :D what colour u doing ur 7? ive seen a few recently, but never when im on mine :cry: i always see a 98 green zx7 everyday riding in moorabbin.
ZXRboy, I want to do mine Metallic Blue, with White tail and nose and lower part of the fairing (In the usual areas), Gold wheels with blue pinstripes, and maybe some black pinstriping to define the blue and white edges, then some new decals (MINUS the HUUUGE NINJA logo) :D
I redid my front brake disk carriers and brake calipers in Gols last time too, I might do that as well.
Greyghost, what does your bike need to get back on the road ??
Hey dutch, what do you mean about HG ?? :?
ZEN and the art of trying to get my *%&^$ motor to work ..... Where's my Tap and Die set again ????
- Pass me the Angle Grinder nurse.
Hows the box mate..?
Kwakka Kilt
hoffy wrote:Hows the box mate..?
Hey Hoffy, still waiting on the parts I bought, but in the meantime I have been watching how I change gears (ie, not flogging the bike into the top of 1st, then trying to ram into 2nd ...), I now take a slightly more measured and licence friendly approach.....
I now load up 1st until about 9 to 10 thou rpm, and change - off loading the gearbox a bit smoother, I can now feel a definite "Chunk" when in 2nd, it seems I can then load up 2nd gear with no dramas, it hasn't popped for the last few days now.
I think I needed to be more forceful with my foot to make sure 2nd was fully home before putting full drive back on the gearbox, sloppy changes are not something this bike likes.
I know this is the 7R's Achilles heel though, and the bike did pop out that one time mid corner whilst leaned over under load, the bike stood up pretty quickly.... Also popped out under full throttle 2nd gear acceleration, but that was a frantic burn off the lights against another bike, so accurate shifting was not on my mind at the time .... :oops:
I reckon having a replacement set of gears, shift forks and shift drum can't be a bad thing, especially for a couple of hundred bucks.
Maybe I will reverse the shift lever, means I would be putting downward force when changing up gears, could only help with positive upshifting ?? :? - I did this on one of my old bikes and liked the way it felt.
Anyone else run a reverse shift ??
dutchy
Post by dutchy »
Just wondering if there will be other zx7r's going to halls gap??
zx7r boy
Post by zx7r boy »
should look nice mate when your done, slap some pics u when its painted, was thinking of doing mine black with gold rims but im starting to like the look of the red now so not sure :roll: hope ur gearbox gets sorted out, ive never had any probs, knock on wood with my 2, first one had 60+k on it, was still going strong unlike my old 20k r1 :x appaently the tpe of oil you use makes a difference, been told to keep away from shell?
