Chain lube
- Strika
re: Chain lube
Can't comment. Never had a bike long enough to need it.
Simmo_ZX9R
re: Chain lube
l use the motul spray on gear..seems better than the castrol stuff imo.
Yeah the rear wheel gets dirty espec if u got green wheels!
l use this stuff by polyglaze to clean the wheels callled typically 'mag wheel cleaner' pretty original huh?!
its a spray type (looks like shaving cream when sprayed) that seems to move 90% of the shit off my wheels, tho a little scrubbing is needed for those stubborn bits of goo.
good for bugs off the fairing too...its gently on paint
Alcoholic slimfast- not only do you look better, but so do other people
Re: re: Chain lube
Hello Simmo,Simmo_ZX9R wrote: Yeah the rear wheel gets dirty espec if u got green wheels!
Try WD40 or equive......
- zx9-2000.gif (13.35 KiB) Viewed 4905 times
"Love Motorbikes"
Re: re: Chain lube
maxima chain wax, been using it for yearsPontikat wrote:Chain Wax, cant remember the name I'll edit it in later. Then Citrus based "goo remover" to get the small amount that flicks off onto the poilshed rim.
Cheers Brett
as long as you lube your chain with something its better than nothing...i like the wax cause it doesnt fling off as much and whatever does is sorta clear anyway
RG
- State: Western Australia
Re: re: Chain lube
I think this is wat u r trying to say...Pontikat wrote:Also i know it has'nt been mention make sure your chain is hot n spin the wheel forward n apply in front at the bottom of the rear sprocket down into the sides of the chain where the "O" rings are.
Cheers Brett
A picture speaks a thousand words
- Smitty
Re: re: Chain lube
SimmoSimmo_ZX9R wrote:l use this stuff by polyglaze to clean the wheels callled typically 'mag wheel cleaner' pretty original huh?!
most Mag wheel cleaners are acid based
they commonly use oxalic acid in various concentrations
and always warn you never to use it on a warm surface (like a wheel)
coz its eats away with the warmer the object...
people think its OK 'coz it comes from plants
but
its also poisonous .. http://www.bartleby.com/65/ox/oxalicac.html
with wheel cleaners, its spray on wash off...
so no harm
but
on your fairing paint....? not nice
- Smitty
re: Chain lube
RG
spot on mate
but
one thing....
the arrow's pointing BACKWARDS
roll the wheel forward.....
in the chains usual direction of travel
spot on mate
but
one thing....
- Nanna10r
- Team Ninja
re: Chain lube
Maxima is the gear i use
Good to see others have arrived at the same conclusion as me. Its the best out there if you have coloured/polished rims by a mile.
Snapper good piccie mate but i apply it just in front of the rear cog (da big'n) too bloody hard to get access to the smaller drive cog, with the tip it up on the side stand method that i use.... must buy a race stand one day.
I used some mag wheel cleaner on the fzzr6 & it discoloured & stained the painted surfaces on the new disc rotors from aussie discs. So i tossed in in the boot of the Pontiac, wont use it on my scoots again.
cheers Brett
cheers Brett
- aardvark
re: Chain lube
I just smother mine in lube... can't have too much I say.
- Aussie Ninja
re: Chain lube
Another good thing to get the fling off off your rims (say that ten times fast) is Mr. Sheen. Not the late great Barry but the furniture spray.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
- javaman
- Bike: GPz900
re: Chain lube
Seems like I'm shopping for Maxima
As for the rims, petrol would do fine
http://GPZninja.blogspot.com/
- Smitty
Re: re: Chain lube
Aussie Ninja wrote:Another good thing to get the fling off off your rims (say that ten times fast) is Mr. Sheen. Not the late great Barry but the furniture spray.
classsssic...!
- sp500
re: Chain lube
Maxima chain wax here too, don't forget to clean(kero) ya chain because it will still flick off even with non-flick chain wax, use to get alot until i woke up and cleaned it, no flicking now.
As far as rims i used some degreaser on a rag mixed with water, did the job just fine.
2004 Green ZX10R
YAPPA
re: Chain lube
i use silkolene chain lube, bit messy if u use 2 much but me m8 gets it 4 me 4 free, (in marikas voice) so me no complain
- gixxerdave
- Bike: Scooter
re: Chain lube
never tried it myself but a mate of mine swears by furniture polish for getting the gunk off your rims..
