Had a bit of a look around the bike this weekend.
Air filter was quite greasy / black, so I washed it out, dried it properly, checked the plugs, and cabling.
The plugs were all a nice light brown colour, even for all 4 cylinders, man the plugs are along way down in the block on the 7r
I found the Positive terminal lead to the battery was loose ..... Nipped that up quick smart.
Cleaned the loom, checking for snags, catches, perished insulation obvious damage etc.. All good.
All back together, ran the bike until the fan kept kicking in, then turned it off.
Started again, 1st crank !!
Tried again, 1sr crank again !!
You beauty, let's see how things go over the next few weeks, but I reckon it's Job done
Thx for all the words of wisdom
