ZX7R Problem. {meltdown pic added}
- gpxpunk
 - Bike: Don't have one
Re: ZX7R problem.
yeah tried clutch starting, nothing!!!!  will try it again tomorrow, since i have tomorrow off. but apart from that i might have to take it down to a mechanic, to see wtf is going on, or if Joe could see since he knows everything about a 7!!!!! Hey greenblood got a minute hahaha.
							1987 GPX250R. memories
2002 ZX7R . sold!!!!
- timmyrocks
Re: ZX7R problem.
have you got multimeters? a few checks with them will point you in a closer direction
Team Crash "09"
WR125 2004 Husqvarna
						Team Crash "09"
- gpxpunk
Re: ZX7R problem.
no that is the one thing i dont have.
- gpxpunk
Re: ZX7R problem.
ok so ripped the carbies off, took the rocker cover off. thought maybe the cam chain was stuffed, but nice and tight. smelt of burnt oil as i havent had a chance to do an oil change. spark plugs need replacing, but none of them have spark going to them????? worked out the spinning noise after i release the start button is infact the started motor or something near it. battery is flat now.
Cleaned the side stand switch completely and also bypassed it and still no.
- timmyrocks
Re: ZX7R problem.
y did you take the carbs off if you dont have spark!!!
get an elec diagram and follow to the coils, buy a set a multimeters and start testing power
Team Crash "09"
						Team Crash "09"
Re: ZX7R problem.
As said already, Startor sprag sounds cactus,whan stuffed it can sometimes grab slightly then let go, when it lets go the starter motor spins up, probably the spinning sound you can heargpxpunk wrote:worked out the spinning noise after i release the start button is infact the started motor or something near it.
- gpxpunk
Re: ZX7R problem.
had to take the carbs off to get to the idle control wire since i unscrewed it all the way off lol. plus wanted to check under the rocker cover and could not remove the cover with out take the carbs off, bit tight these 7's.kawasaki250 wrote:y did you take the carbs off if you dont have spark!!!
thanks Rob i will be checking the starter motor soon. Will be removing it this weekend. and seeing wtf is going on.robracer wrote:As said already, Startor sprag sounds cactus,whan stuffed it can sometimes grab slightly then let go, when it lets go the starter motor spins up, probably the spinning sound you can heargpxpunk wrote:worked out the spinning noise after i release the start button is infact the started motor or something near it.
On a quick note. When you take the spark plugs out, that should make the engine have no compression??? if so, if you place it in gear shouldnt you be able to push the bike without the clutch in or wothout or both? {just following all avenues}
Also while i have been pulling apart Gen, i have come to relise this beautiful girl has been very mistreated!!!! but i still have abit under 4months to get her ready.
Re: ZX7R problem.
You wont see muchgpxpunk wrote:thanks Rob i will be checking the starter motor soon. Will be removing it this weekend. and seeing wtf is going on.kuda:
- gpxpunk
Re: ZX7R problem.
robracer wrote:You wont see muchgpxpunk wrote:thanks Rob i will be checking the starter motor soon. Will be removing it this weekend. and seeing wtf is going on.kuda:but at least you can check the starter. as for the starter clutch you would have to dig deeper
whay should i be checking then??? on the starter that is.
- timmyrocks
Re: ZX7R problem.
once you have the started off run wires to it, positive to the tang and negative to the body and see how she spins up. MAKE SHORE YOU PLACE YOUR FOOT/ PUT IT IN A VICE so it doesnt run away
you will still have some resistance form the engine as your trying to squeeze air in the cylinder out a spark plug hole
 you most prob will have to sit on the seat if the rear wheel just stays locked
 hehe.
have you charged the battery and given it another go? and have you located the starter solenoid?
Team Crash "09"
						Team Crash "09"
- gpxpunk
Re: ZX7R problem.
yeah changed the battery, and the starter solenoid should be the one near the fuse box under the seat isn't it.kawasaki250 wrote:once you have the started off run wires to it, positive to the tang and negative to the body and see how she spins up. MAKE SHORE YOU PLACE YOUR FOOT/ PUT IT IN A VICE so it doesnt run away![]()
you will still have some resistance form the engine as your trying to squeeze air in the cylinder out a spark plug holeyou most prob will have to sit on the seat if the rear wheel just stays locked
hehe.
And thanks for that as i said above ill rip the starter off this weekend and see if it is stuffed or not.
- timmyrocks
Re: ZX7R problem.
follow your positive lead from the battery, it will go striaght to the starter solenoid. this has a fuse in it, it will have the wire coming from the battery, then into the body then to the starter,,,, try bridging this with a screwdriver
Team Crash "09"
						Team Crash "09"
- gpxpunk
Re: ZX7R problem.
so you mean bridging the 2 wires that are going into the it, instead of allowing it to pass through it.kawasaki250 wrote:follow your positive lead from the battery, it will go striaght to the starter solenoid. this has a fuse in it, it will have the wire coming from the battery, then into the body then to the starter,,,, try bridging this with a screwdriver![]()
- timmyrocks
Re: ZX7R problem.
yer pop the caps off the solenoid and get a screw drive and touch both of them, dont be afraid of the sparks
. do this before you take to starter off. this will totally bypass all the safety switches and ignition
Team Crash "09"
						Team Crash "09"
- gpxpunk
Re: ZX7R problem.
cool ill try it tomorrow and see what happens, the bike is in pieces at the moment.
