Speedo Healer
Re: Speedo Healer
z900/zx9 wrote:[]
It would be for the new ZX14 mate :D
I don't like LIMITS!!!!!!! :twisted:
Hey heres an idear why not ride the farker when ya get it and when all evidence of Kishy strips has been removed then worry about making it go faster ;)[/quote]
Like kishy strips have anything to do with straight line SPEED :kuda:[/quote] Yeah well eventually after your big straight line speed you will have to go around a corner :P[/quote]
Ya fucked up all those quotes didn't ya :lol:
bent77
Re: Speedo Healer
Post by bent77 »
If you want to know your true top speed try using a GPS. Most have battery power and will stick to the windscreen. Some models will even record your top speed so you dont need to look down. Any tips on which wire to use(2000 zx12r) to add a lighter plug so my bike can supply power the GPS?
gordo
Re: Speedo Healer
Post by gordo »
Hi seiko1,
I have a healer on my ZX14 and it is an easy fit and works well. Did it for accuracy of speedo (both speed and distance (odometer) rather than eliminating the speed limiter.
I used a GPS to set mine up and found the factory setting to be between 4.5% and 5% generous.
You can get your speedo accurate to around +/- 0.1 km/h.
Tyre wear and tyre inflation will affect the settings but not by much.
Worth the investment as it is easily removed and put onto your next bike or resold.
Regards,
Gordo
Re: Speedo Healer
gordo wrote:Hi seiko1,
Regards,
Gordo
Cheer's Gordo and welcome to KSRC :kuda:
Re: Speedo Healer
TRE has arrived..............not much to it :?
P1010773 (Medium).JPG (61.11 KiB) Viewed 1101 times
P1010774 (Medium).JPG (79.9 KiB) Viewed 1101 times
