Wireless Router Problems
Re: Wireless Router Problems
tape wrote:will give it a try tomorrow Ian, the other puter is now currently occupied... bloody kids :roll:
cheers and thanks
no probs...but get the manual out and have a read
go to section 6 Page 49...it shows you how to do it !
maybe have a drink beforehand too... :kuda:
MrWasabi wrote:grab the manual, because not all routers have the same default ip. .....
the Belkin manual for Micks wireless jobbie says it defaults to 192.168.2.1 on installation
so he should be right
Wireless is easily fixed..........plug in the ethernet ;) ........fucken wireless shit drives me fucken insane should get rid of it altogether god damn shite faced fucken shit :D
Nosferatu
Post by Nosferatu »
Is there interference on your wireless network from another device or are you just trying to optimise/increase signal strength of the network? If you're trying to increase signal strength, try moving the modem to a more direct path to each device. The more obstacles the signal has to go through (especially things like microwaves, fridges, walls, anywhere that has a reasonable sort of electromagnetic field), the weaker and less reliable the service will be, especially for interweb use. If there is something interfering with the network and you know what the device(s) is that is causing it (cordless phone, baby monitor, bluetooth devices etc), try and find out the channel that it runs on too and set the router to at least 4 channels from it. As there are only 11 channels in the 2.4ghz band, they do overlap, so the farther away each device is from the other, the better off you will be. Remember though, that your neighbours will be using wireless devices as well, so the interference could be coming from outside your house. You can also change the setting on your router via the laptops as the only thing that will change is the channel the router broadcasts on, not any setting on your computers. The computers will automatically find any wireless network in range, regardless of what channel it is on. When you have changed the channel on the router and hit apply, it should restart (or ask you to) the router, drop the network and come on again. At that point the computers will reacquire the connection and away you go.
corvus2606
Bike: ER5
Post by corvus2606 »
if its an older router, no, you cannot change the frequency from the 2.4ghz range.
if you have a newer router, and newer wireless cards, you can use the 5.8ghz range,(or wireless n as its referred to).
but yes, changing the channel could fix it. the main issue you will find here is that most devices that cause interference will be spread over up to 6 channels, so picking a good one is pretty hard to do
2002 GPX250 - Gone
2003 ER-5 - Gone
B-Ry
Bike: Ninja 250
Post by B-Ry »
did you ever get this resolved?
Team Crashed '09
tape
Post by tape »
nah the bastard wouldn't do what I wanted... or was that I didn't know what I was doing... :roll:
I'm in a situation where my av sender that I use for my foxtel to be sent to another room is the same 2.4GHz as the wireless router, and the 5.8GHz is what we have for our wireless phone. So I'm farked if I know... It will take someone who knows what they are doing to fix this not me fuckin up everyones suggestions... :shock:
Mick :drinkers:
http://www.insptag.com.au
I told you...a bloody great long Ethernet cable connot be beaten for reliability :kuda:
Wireless is somethng you would expect a xxxx gold drinker to be using :lol:
B-Ry
Bike: Ninja 250
Post by B-Ry »
I am offended by the suggestion I am a xxxx gold drinker :p long cables get in the way whilst your sitting on the coach
Team Crashed '09
B-Ry wrote:I am offended by the suggestion I am a xxxx gold drinker :p long cables get in the way whilst your sitting on the coach
I have been drinking xxxxGold for a decade. :shock:
It's a pet hate of Micks :?
