Tires for 250R
Nelso
Re: Tires for 250R
Post by Nelso »
There is a reason the skinny tyre is on that rim. It's not like car tyres that have a flat tread. When you fit a wider tyre to a bike you change the profile of the tyre which changes the way the bike and tyre perform. If you look at the picture above you can see that the skinny tyre has more angled sides than the wider tyre. You need those sides to be on that sort of angle to grip the road while you have the bike lent over going around a corner. If all you want to do is ride in straight lines then go ahead and fit the wider tyre but if you want it to go around corners you are better off leaving the skinny tyre on.
woo9
Bike: Ninja 250
Re: Tires for 250R
Post by woo9 »
yeah, compared the two tires above, we can see the dramatic difference in shape. but if we check same tires in two sizes of width, what's the story then :roll:
-b-r-e-n-t-
Re: Tires for 250R
Post by -b-r-e-n-t- »
The factory tyres aren't great so just upgrade them, but use the same 110/70, 130/70 set up. You would want to keep the 250 nimble to tackle those twisties :twisted:
2012 Black ZX-10R - Roady
2010 Black ZX-6R - For Sale
2010 Blue Ninja 250R - Sold
...boldly going nowhere...
Re: Tires for 250R
woo9 wrote:yeah, compared the two tires above, we can see the dramatic difference in shape. but if we check same tires in two sizes of width, what's the story then :roll:
:? if the tyre is the same model but different size, its still a different size... unless ive missed the point of this post :roll:
Nelso
Re: Tires for 250R
Post by Nelso »
:lol: Yeah, you will still get the same result as the picture above. Fitting a tyre two sizes bigger on any rim will change the characteristics and grip of that bike quite a bit.
P4nza
Re: Tires for 250R
Post by P4nza »
I have the 130/70 17 Pirelli Sport Demon on the rear and it has performed exceptionally lately!! its very sticky when it gets hot and being a 130 the trye is a lot wider than the stock IRC "road losers" that the ninja 250 has on there stock... i didnt notice until it was on the bike...
If you want a good tyre either go for the BT45 or the Sport Demons :kuda:
MrWasabi
Re: Tires for 250R
Post by MrWasabi »
might seem like a bunch of dribble and not what you want to hear but what Nelso and Rob are saying is correct. i had a 170 on the back of my bike, ended up squaring the tyre out, and with about a 2-3cm chicken strip either side of the tyre. For the life of me i couldnt tip that bike into corners any harder than what my experience allowed.
Finally ditched it and i got a smaller, but the factory standard 160 on the back, right off the bat i could tip it in just by blowing on the handle bars, and chicken strips? dont exist any more!
If you are getting tyres for the look, to impress the ladies then hell, buy a 190 and stick it on there. If you want more grip and want to enjoy riding and push the bike to its limits then get the tyres Firey suggested in a factory standard size
Mistakes:
Re: Tires for 250R
Did you pick up the "tyre" business or what?
Mike
Re: Tires for 250R
Post by Mike »
Your better off keeping the same tyre profile and getting a better tyre then the OEM.
Pirelli sports demons are a reasonable tyre for road riding and last well with good grip. Haven't tried the Bridgestones but from most reports they are also a good sticky tyre. If your just changing the tyre profile cause it "looks cooler" then your doing it for all the wrong reasons. a) A 150 is not impressive b) All it will do is change the steering of the bike (probably for the worst).
Just get good sticky tyres and you will be amazed at the difference in feel you have without compromising the handling.
Join Team Ghetto Racing
Re: Tires for 250R
Welcome!! :kuda:
With regard to handling and tyres, don't forget tyre pressures as well, and the effect it has on the handling and feel of your bike.
I've had both BT45s and Sport Demons (like both a lot, BT45s probably my favourites), and I'd say go with either of these all the way mate, in the standard size!
I'd be trusting what these guys say 100% ;)
Re: Tires for 250R
tim wrote:I'd be trusting what these guys say 100% ;)
Tim.........you should transfer all of your money into my account.......trust me, it's the best way :lol:
brausi
Re: Tires for 250R
Post by brausi »
What's wrong with thin tyres... :lol:
Still Rolling...
[b]05' R6 - Tracky[/b]
[color=#00FF40]05' ZX-6R - Tracky[/color]
2008ninja
Bike: Ninja 250
Re: Tires for 250R
Post by 2008ninja »
Go for the pireeli sport demons they are way better tan stock, Got a flat a few weeks ago and oppted for the sprt demon, wears much more even and is a harder compund and its the same size as stock but looks bigger. Retails for around $140
Slow in Fast out. " thats what she said "
2008ninja
Bike: Ninja 250
Re: Tires for 250R
Post by 2008ninja »
