Blown head gasket?
cylonagent
- Bike: ZZR250
Re: Blown head gasket?
It has primary and reserve
- tim
Hhmm.... someone who actually knows what they're talking about will be along soon enough
You could always try popping the fuel line off and pouring some fuel down there? Buuut with only main and reserve does that mean the carbs gravity feed?
cylonagent
- Bike: ZZR250
Just an update, gonna check cam timing and will now have to remove spark plug thread from the head
what ever happend to hard steal that could handle a lil bit of torsional stress? This soft steel just falls apart just from lookin at it funny
- dickfaber
- Bike: ER6
baby zzrs, like baby gpx's have a fuel tap which says on, off and prime. the tap is a vacuum operated pump. prime allows for priming (oddly enough) when youve been a plonker and run it completely dry.cylonagent wrote:Just an update, gonna check cam timing and will now have to remove spark plug thread from the headwhat ever happend to hard steal that could handle a lil bit of torsional stress? This soft steel just falls apart just from lookin at it funny
check the basics - got spark?
got compression?
is there fuel in the carbies (drain them to see)
are all the vacuum lines installed? like pump, bloking caps for carb balancing etc
are the plugs getting any fuel?
cam timing - it is a c&nt to check with the engine in; and a bigger c&nt to reset with it in
how do i know? - first little kwak was a gpx 250 that came in many boxes and a price tag of $100; after it got going, did about 10 more of them and zzr's
cylonagent
- Bike: ZZR250
Spark... yes
Fuel.... yes
Compresion... bloody hope so just did top end rebuild
Fuel.... yes
- dickfaber
- Bike: ER6
cam timing?cylonagent wrote:Spark... yes
Fuel.... yes
wet plugs?
GPZ_Jim
- Bike: GPz500
maybe consider getting a cheap runner off fleabay or somethin n pinch the donk from that till ya get this one sorted? as said above the gpx and zzr twofiddys share the same engine.. heaps easy to find more of them
hopefully u get some progress one way or the other
cylonagent
- Bike: ZZR250
So iv been told its a real prick to prime the carbs once they have been drained and u have to just keep turning it till it starts is there any truth to this iv drained and recharged the batteries 3 or 4 times doin this can any1 confirm if this is the case?
cylonagent
- Bike: ZZR250
There is a drain on them? Iv just been blowing on the breather tube and when I do yes fuel does come out
- TONY-J
- Bike: ZX14R
at the bottom of each bowl there is a screw, that is the drain plug
84 RZ350
84 GPZ900r
91 ZZR1100
06 ZX14
84 GPZ900r
91 ZZR1100
06 ZX14
- TONY-J
- Bike: ZX14R
if you have spark and compression and after turning it over your plugs are wet, then i would say you are more than likley to be 1 tooth out on the cam timing,
good luck
good luck
84 RZ350
84 GPZ900r
91 ZZR1100
06 ZX14
84 GPZ900r
91 ZZR1100
06 ZX14
cylonagent
- Bike: ZZR250
Yea its timing, I don't have the tools to hold the clutch hub while I undo the locking nut so I'm giving up and taken the engine to a MOTO mechanic to get it sorted. Now I'm just worried that I have bent the valves with the piston when I tried to start it after the 2nd attempt at fixing it any1 know how tough they are?
- TONY-J
- Bike: ZX14R
if you are only 1 tooth out and or the engine turns over freely like it should or you haven't forced it to turn over when it didn't want to you should be alright,
i had my tensioner fail on a gpz900r and the cam chain jumped a tooth on the cam and it did no damage, but that may have just been luck
84 RZ350
84 GPZ900r
91 ZZR1100
06 ZX14
84 GPZ900r
91 ZZR1100
06 ZX14
- born green
If only one tooth, it will be fine.
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
