Marty and Maximus have hit the nail on the head mate. First thing - being a speedway motor, you can bet your house it was built to run on methanol. That means really hi-comp (maybe up around 13-14:1). Someone who can build cams must have done up a set to suit the big-bang configuration - I would be checking with someone like Ivan Tighe in Qld about the cams - he has been doing cams for 40-odd years and may know something about the cams in this motor ??.....born green wrote:.....It has a big kitted engine, dont know what brand, nor do i know what camshafts its running, but is running 34mm CV carbs, now the problem is it doesnt idle very well, off idle it revs sweet and hard, but when the throttle is closed it runs rough.
The old man has done everything, stripped and rebuilt the carbs many times, he has even tried another set off his other kawaka, replaced all the rubber manifolds, ect, checked and rechecked timing, everything....
All he know about this engine, is that it was built by a guy that built engines for speedway outfits, hence the big bang engine.
Would this rough idle be normal with this type of engine???
big lumpy cams and hi-comp, the idle on this motor when it was in an outfit burning methanol, would be well up over 1500rpm and probably closer to 2000rpm - they just are not designed to idle down low cleanly at 1100 rpm like a stocker.
remember that even on a stock Z motor, 1&4 and 2&3 cylinders fire at the same time - but it is a 'wasted' spark arrangement where the spark fires on the exhaust stroke of the second cylinder in each pair (ie as #1 fires on the power stroke, #4 will also be firing, but on the exhaust stroke, where it makes no difference)......Has your old man split the cases to check out the crank mods himself ? Is he 110% sure it is a big-bang motor ?
Good luck with this one, it sounds like a really interesting piece of kit alright !!
