Bit of bling for Bronc
Re: Bit of bling for Bronc
timmyrocks wrote:Nice 8)
That tank if effing huge!!!! The drz would be good for nearly 300klms with that wouldn't it??
The big question .... is John good for 300+klms :lol: :kuda:
Post by laidback »
Enough cheek from you mate...you had to sell it because you couldn't do it... :twisted:
Depends on the temperature...less than 10c and I stay in bed...more than 30c I head to the air con... :kuda:
Post by laidback »
Well I got a bit busy today and fitted the wheels up for a trial - thanks timmyrocks (you sure do)...the spacers work a treat. Just need to sort out discs and sprocket.
I have a mate down here that is crazy about Suzuki's and while he has been good about me getting one I want to remove all the yellow so the bike will be black and white. Didn't get around to fitting the tank so will do that tomorrow.
Fitted so far:
CBR250RR wheels (trial fit only)
Black front and rear guards
Sargent seat
B&B rack
timmyrocks
Post by timmyrocks »
Ah sweet mate glad the spacers worked out ok :)
Team Crash "09"
WR125 2004 Husqvarna :P
Post by laidback »
Always a good day when you go shopping for bike stuff... 8)
Chain and sprocket for motard setup
Bar risers for the fat bars
Assorted bolts to hold things together
But wait there's more...got home to find 4 parcels waiting... 8) 8)
Vapor dash
Free power harness...direct cabling helps charge battery better than original wiring
Spacer to use where original speedo fitted on original front wheel
I'm off to play in the man cave(s)... :kuda:
Ha got some gear there John :shock: 8)
Post by laidback »
Trial fit done...short fang to test ride 8) 8) 8) and now pull apart and make sure everything is done up tight etc... :kuda:
Wow no 9 :( but it gets along nicely. :kuda:
JetPilot
Post by JetPilot »
Nice one John 8) Have you done any mods for more grunt... IE airbox mod is easy and gains a shitload of grunt with exhaust. I use to own one dont forget... PM if ya want some ideas.
Kawasaki Z1000r 2012
