Brakes gone or brake fluid- minor incident.
- TyM2Go
- Bike: Ninja 250
Re: Brakes gone or brake fluid- minor incident.
Yep, Will have a crack at it tomorrow. Downside is if i dont bleed it correctly brakes won't work. So i'll stick to my driveway as the test area lol. Most of the video's i saw before making this thread essentially all used these "professional" bleeding kits. I am eager to learn unfortunately don't have any one to guide me when it comes to bikes. So figured i'd use youtube & the help from the community.
╭∩╮(︶︿︶)╭∩╮the police.
- TONY-J
- Bike: ZX14R
as sturx said......''my 'bleeding kit' is phillips head s/driver-8mm ringy-big coffee jar with a hole in the lid-2ft clear tubing to fit on bleed nipple & some clean rags''.
this is all you will need and all i have ever used, the coffee jar and clear tube is only to catch the brake fluid so it doesn't get all over your bike and so you can see any air bubbles.
you should be able to tell if they are bled properly straight away or at the most walking pace.
let us know how ya go.
84 RZ350
84 GPZ900r
91 ZZR1100
06 ZX14
84 GPZ900r
91 ZZR1100
06 ZX14
- dickfaber
- Bike: ER6
try this, yes i know its for the old gpx250, but its written for a noob with no experiance
http://faq.ninja250.org/wiki/How_do_I_b ... e_lines%3F
this is worth a good read too
http://faq.ninja250.org/wiki/2008_(and_up)_EX250J_Info
infact the whole wiki is worthwhile
http://faq.ninja250.org/wiki/Main_Page
and no, its not my wiki
- Nelso
z900/zx9 wrote:Here is some straight up advise,if you dont know how to do the brakes get someone to do them and watch what they do.2-3 mm on pads Mmmm get new pads.Do some training or all the other things that you are focussed on might not happen as u maybe bent ,broken sore or worse.
- TyM2Go
- Bike: Ninja 250
Sounds good, the site is very helpful. As for brake pads decided to go with either EBC or SBS don't know which one is better, unless someone else has had some good reviews with other one's. Will head to the store to buy some super dot 4 brake fluid in a bit and then start on the diy job.
- born green
TyM2Go wrote:Sounds good, the site is very helpful. As for brake pads decided to go with either EBC or SBS don't know which one is better, unless someone else has had some good reviews with other one's. Will head to the store to buy some super dot 4 brake fluid in a bit and then start on the diy job.
either there both good brands, pick the cheaper out of the two
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
- TyM2Go
- Bike: Ninja 250
Well at a crossroads at the moment. Took it down to the guy at mcas to buy the brake fluid & pads (were not in he has to order them).
He checked my bike said pads still have a lot of life on them. Which i found odd looked up the kawi book it said 1mm = change.
He said there wasn't any brake fluid in it so opened it up as he couldn't do it and....... to our surprise the brake fluid is topped up. Felt like a complete idiot at this point. He checked my rotar's & said front one's are really smooth compared to the back as if it were glazed with something. Bought brake cleaner fluid as instructed, to clean the rotar's incase anything was on it. Done all that and still nothing. Any idea's anyone? I didn't have this issue before just started up about wednesday.
- TONY-J
- Bike: ZX14R
is there any pressure at the lever.
still bleed them and see what happens.
84 RZ350
84 GPZ900r
91 ZZR1100
06 ZX14
84 GPZ900r
91 ZZR1100
06 ZX14
- TyM2Go
- Bike: Ninja 250
At the moment the resistance is at about half way. As in i can only pull the lever all the way as hard as i can and it comes to about halfway and a bit.
- born green
TyM2Go wrote:At the moment the resistance is at about half way. As in i can only pull the lever all the way as hard as i can and it comes to about halfway and a bit.
This all sounds a bit, (lot) confusing.... without having a look, i think most will be at a loss to to work it out now
If ur lever is only coming halfway back, then u should have brake pressure???
I recommend that u talk someone here to go have a look, or try and get it to them???
If pads ok, fluid ok, disc's ok, than it shoud be ok...
Are u sure u didnt panic at the time???
Mate i taught learners for 7 years.. and the hardest thing was trying to teach people to stop the dam thing
Learning to pull the thing up in a panic stop is something u really need to learn... no point trying to learn when u life depends on it... that dont work.
Just get them sorted correctly, brakes are sort of important
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
- 6maniac
- Bike: Z750
Fitzy, do yourself a favour, and change your location from "lost" to a suburb.
Someone may swing by and give you a hand ....
Stuzrx
- Bike: Z750
Do you have adjustable levers?? If so you may have them adjusted too close to the h/bar???
- Strika
I would put money on the fact that you just fucked up and there is nothing wrong with your brakes.
- born green
thats sort of what i was trying to say.!!! was trying to be polte. something different for meStrika wrote:I would put money on the fact that you just fucked up and there is nothing wrong with your brakes.
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
ding ding ding ding!!!Strika wrote:I would put money on the fact that you just fucked up and there is nothing wrong with your brakes.
And we have a winner!!!!!!!
