Best brake pads
- Blurr
Re: Best brake pads
Yep worth it for sure.
Re: Best brake pads
This is probably the single biggest improvement you can make, regardless of the lines. If the lines are only a few years old they will still work OK, just not give the same sort of *crisp* feel you get with braided lines. I fitted a 19mm radial m/c to my 12 a few years ago - fantastic improvement over the OEM m/c. Already had braided lines fitted.Mickwitchy wrote:.....Is it worth doing with stock brake lines? Since this is (for the moment) still a street bike, the abs is still hooked up so won't get braided lines until that goes....
You can use any radial m/c that fits - I used a Gixxer 600/750 m/c, think it was an 07 model ?? Ebay is the place to look for bargains, especially US.
Mickwitchy
- State: ACT
Re: Best brake pads
How do I know if the one I'm buying is better than my oem one?
- Blurr
Re: Best brake pads
Mickwitchy wrote:How do I know if the one I'm buying is better than my oem one?
Trial and error. Give them a go.
The biggest factor with all this stuff (like tires) is that everyone has a different opinion. Some say ebcHH where others will say they are crap.
Get the info and try a couple that may suit you
Re: Best brake pads
Russ - I think Mick is talking about a new m/c, not the pads. But you are dead right about the pads, they are all different and some pads suit some punters and not others - with these, just like tyres - its always about what works best *for you*........Blurr wrote:Mickwitchy wrote:How do I know if the one I'm buying is better than my oem one?
Mick - check the size of the m?c on your bike. It will have 14mm or 5/8" cast into the body, generally underneath.
*Any* other m/c that has a larger bore - ie 19mm or 3/4" - is going to be better than your stock one. That is exactly why I just grabbed the cheapest one on ebay that I found. It does not have to be a kawasaki m/c at all. Could be Yammie or Honda etc - there are different designs which suit some bikes better than others in terms of fit and clearance to fairings etc - you either need to check out a local wrecker and have a look at a few - or just take a punt
- fireyrob
Re: Best brake pads
Just do the fluid to start with. 1 mod at a time to feel the difference. If your regularly at the track braided lines will help. Not sure about the abs as Ive never owned or ridden with it. I havent read anywhere anyone needing to replace the MC in the current zx10
I could be wrong and sure someone will arc up if I am
Re: Best brake pads
The stock mc is ok, it's the calipers that sucked on all the old 10's.fireyrob wrote:Just do the fluid to start with. 1 mod at a time to feel the difference. If your regularly at the track braided lines will help. Not sure about the abs as Ive never owned or ridden with it. I havent read anywhere anyone needing to replace the MC in the current zx10I could be wrong and sure someone will arc up if I am
But a bigger bore m/c won't hurt it. Pushes more fluid
- fireyrob
Re: Best brake pads
True but whats the go with the current 10? Thought the setup was meant to be pretty good? Bigger MC wont hurt but is it necessary just yet? The bike is still completely OEM.
- Tack
Re: Best brake pads
Dunno how you guys figure that a larger master cylinder gives more pressure. It's the exact opposite. Small master gives greater pressure but travels further feels spungier can create less confidence due to travel but can give a more finite brake point......large master gives less pressure and travels less distance feels harder gives greater confidence but harder to find the finite brake point.
- fireyrob
Re: Best brake pads
Tack, I think on the older 10's the extra fluid helped disguise the issue with the calipers. But on the current 10 is it an issue?
- Tack
Re: Best brake pads
I'm not saying that it is an issue on this bike. I'm just saying that larger bore master doesn't give more pressure.
There is nothing wrong at all with the advice that's been given. it's all good excellent stuff however I wanted to clarify that point.
Re: Best brake pads
Not really, some race bikes are using the brembo, but while using a bigger piston it also adjusts the ratio, so kills both birds. More fluid ad better pressure.fireyrob wrote:Tack, I think on the older 10's the extra fluid helped disguise the issue with the calipers. But on the current 10 is it an issue?
But completely overkill with stock brake lines.
- Blurr
Re: Best brake pads
Tack wrote:Dunno how you guys figure that a larger master cylinder gives more pressure. It's the exact opposite. Small master gives greater pressure but travels further feels spungier can create less confidence due to travel but can give a more finite brake point......large master gives less pressure and travels less distance feels harder gives greater confidence but harder to find the finite brake point.
I think you may be hung up on the word 'pressure'
Larger bore, moves a greater amount of fluid thus reducing the lever travel to braking point. I simply meant, more fluid, more force = greater pressure
- fireyrob
Re: Best brake pads
Better still let us all ride the 10 Mickwitchy then we can offer more advice
Re: Best brake pads
fireyrob wrote:Better still let us all ride the 10 Mickwitchy then we can offer more advice
