I have a PK Power quickshifter on mine, its basically a copy of the dynojet one, but much cheaper. Never had a problem with it once set up, but I have done 2 gearboxes..Nelso wrote:So what's the best one to run on an '04 ZX10 with a Powercomander? I remember something about Madkaw having trouble with putting one on.
Someone at the track the other day said I would gain half a second by fitting one. Was he full of shit or are they that good to have?
You need the power commander to run it, but on the later models with 8 injectors you also need the expansion module... We found that out after fitting one to Blurrs 08, hence it went onto Watties 06.....
http://www.pk-power.com/quickshifter.ph ... n99tk3d397
