Glad I've got spares.......
All GPx and GPz Models
Re: Anyone can build a bike.......
love the job on that fork nut !!! :kuda: :kuda: the heat would have helped loosen it a lot as well.
Its good to have spares eh ??
Daisy
Bike: GTR
Post by Daisy »
Makes my bike look cosmetic.
Good job you have spares.
dutchy
Post by dutchy »
So I woke up and thought to myself, what can I destroy today? Went into the shed and kept stripping the 2nd bike. Decided to take of he rear wheel and suspension. Took of the nut attached to the rear axle but it was still stuck solid. It was jammed up in one of the spacers but I ended up knocking it out after a little bit of work. Frustrating.
After this it seemed as though every nut and bolt simply refused to be removed. I had to literally swing off them until I heard that glorious almighty cracking sound that come from old shit finally snapping loose. :kuda:
In the end I took pretty much everything off and was just left with the engine. Another few frustrating bolts had issues with removing themselves from their mounts, but they gave eventually as well. I noticed some damage to one of the "cooling fins??" on the engine right near the rhs front mount. There also appears to be re-welding work done near the engine mounting point on the frame.......crap. It looks as thought the bike as gone over and the canister section that the engine mount bolt goes through has been punched out of the frame. The repairer has re-attached the tube to the frame. I've cleaned it up a bit so it doesn't look too bad. Here's a pick of the two frames, try to cap your excitement.
In the end everything came off, and for today only, nothing was destroyed. Still glad I've got spares. :lol:
Re: Glad I've got spares.......
Sheesh just reading that gives a good idea of what's involved in bringing bikes back from age and neglect. Glad you've got spares!
dutchy
Post by dutchy »
Thought i'd post a little comment on where it's at.............GOING ABSOLUTELY NO WHERE!!!! :lol: :lol: :lol: :lol:
This all happened a little while ago I was examining the 2nd frame from all angles. It didn't look good. I found an engine mount (tube running through the frame near the front) that initially appeared to have been re-welded in but then it became obvious the weld went right around the frame tube. SHIT. Another frame weld was found near the bottom frame on the same length of tube. Also noticed that right down at the last 20 cms of the rear the subframe has been re-welded. Has this thing been completely busted up?
Looking at the frame again it appears the main tube at the top of the fairing looks like it's bending off to the right hand side. I put a straight edge on it to confirm, yep, bent. Re-examine a third time and now the bent frame is unbelievably obvious to me. :cry:
So i'm left with two munted frames. One with a good main frame but shit subframe, and one with a shit main frame and half decent, but not perfect subframe. A blending of the two may be required. This is not likely to happen any time soon. I might take some pics and post them up tomorrow.
And that is where it's at.
Daisy
Bike: GTR
Post by Daisy »
At least you have spares. :P
I have to fix the one frame I've got.
davo231481
Post by davo231481 »
heres a pic i found on psb. http://www.perthstreetbikes.com/forum/f ... ex390.html
scroll down a bit and its the red framed one. looking at the frame and unitral im guessing it was a gpz at one stage
bonester
Post by bonester »
I'm guessing you mean this one:
:D
davo231481
i knew I could count on someone to help out with the techo side of things. Ta Gos. Theres a few electric bikes on that forum too that look a bit out there. i think theyre around page 395+ :kuda:
dutchy
Post by dutchy »
There are some nice bikes on that forum. I might have to spend a night looking through it one day :grin:
davo231481
it will be a very long night. :D you might need 40 days or so
bonester
Post by bonester »
dutchy
Post by dutchy »
-Rego had run out from WA
-No key, starts with a screwdriver
:shock:
If ever you need to check a bikes history, this might be the time :grin:
If I had some cash handy I might have had a look at it, unfortunately I don't :sad:
