new but old topic [ kleen air mod ]
MAXUMIS
Re: new but old topic [ kleen air mod ]
Post by MAXUMIS »
Wattie wrote:When you get dyno'd they always block crimp the hose to get an accurate mixture reading. Unless of course you already have it blocked
Thanks ,I remember now that it leans out on dyno's from what I have seen in vids.
life starts at 200 kph!
MAXUMIS
Post by MAXUMIS »
z900/zx9 wrote:Yep good for a few things but bad if you love that crackle,burble sound,which I do
Haha , mine still gets a loud crack every now and then with it all gone on a high/medium rpm back off :? must be the short pipe ,well that's what I am hoping :lol:
BrettZZR
Bike: ZZR1100
Post by BrettZZR »
Yeah, on the dyno the extra air messes with the CO reading for tuning rich/lean.
That extra diaphragm takes the system out at idle (I think) cant remember exactly why.
The drilling tends to go down next to the plug tube - see here on the ZZR: (Ignore arrows)
the hole with the rubber seal off the plug tube seal with the dowell in it. From what I remember of my ZZR600, the hole was only a few mm in diameter down at the port end.
(-8
mick12
Post by mick12 »
Sure makes a racket when the hoses are pulled from the stock reed covers.The miss is now gone changed the plugs this arvo removed vac pump will do crancase ventilation tomorrow will also add 4 long vac hoses with block offs for equalising the boddies . Must be easier than tryin to reach under pulling caps and hoses and fitting the gauges . Just pull the plugs on the new hoses and connect the gauges to them .I dont think the added weight is going to slow the bike down too much and something to help make service that much easier :)
