Fueling issue (?) with '01 ZX6R
Aussie Ninja
Post by Aussie Ninja »
I-K wrote:
Slow and wobbly wrote:carb synchronisation would cause the bike to idle roughly / hunt around and the problem would be previlant throught the rev range. It never hurts to check the synchronisation but I am doubtful that this is the problem.
Note, however, that the guy who serviced the bike is dirtbike specialist. I wouldn't be surprised if balancing the carbs just slipped off his checklist.
Yeah. It's pretty easy to sync a single. :lol: They shouldn't have touched them, but what you're describing sound exactly like the floats set too lean.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
just sounds like dirty fuel to me. You will need to strip the carbies and clean thoroughly. Change your fuel filter as well.
Only other things that comes to mind is pinched breather tube ? blocked breather in the fuel cap is also worth checking out.
dave#3
Post by dave#3 »
Mark
Two heads are better than one (we've proven that before) so I'd be greatful of your help if you've got the time. As importantly, I'd love to borrow your vaccum gauges. What are you doing tomorrow ?
S&W
I can confirm that it *will* rev through the rev range :oops: ...so can the neighbours 10 doors down !
Dan
Tanks been on and off a few times, I don't think the line is pinched.
Aussie Ninja
My best guess has been float levels, but I'd be really interested to know why you picked it, given that my reason hasn't been posted. The reason I suspect the float levels is that, on our driveway (which is reasonably steep) the bike will splutter and stall - this was happening before the *service* so it was discounted to some extent, but it's well and truly back at the top of my list.
Neilp
What makes you say electrical ? Only interested becuase the reason I went with a fueling problem was that it didn't feel like an electrical issue ... not a good reason, I know, just a feeling.
Everyone else
Thanks for the suggestions, we'll check them all this weekend.
More info
- The problem can be exaggerated significantly by opening the choke
- The spark is good, fat and consistent on all three plugs (OK, four, I was just checking see if you where still paying attention :D)
- Running on reserve makes no difference
- Fuel flow through the tap is fine / consistent when the tank is off the bike
http://www.oz4x4.net/gallery2
Cath
Post by Cath »
Just wanted to add my thanks too. All the suggestions are greatly appreciated.
I'm looking forwards to learning *a lot* about my bike this weekend!
Will update when the problem is resolved
Good luck Cath, looking forward to the 'How we fixed my bike' update...
Slow and wobbly
Post by Slow and wobbly »
one last thing is the check completely disengageing? cable routed correctly? correctly adjusted?
dave#3
Post by dave#3 »
Slow and wobbly wrote:one last thing is the check completely disengageing? cable routed correctly? correctly adjusted?
Presumably 'check' was supposed to be choke ? If so, yes, it is completely disengaging and is correctly routed and adjusted. In fact, applying the choke exaggerates the problem.
Aussie Ninja
I picked floats because I've installed a jet kit on my own scoot and the float height has been by far the biggest pain to get right. I started off rich and at one point went too lean and my scoot did exactly what yours does. I've found mine to be sensative to 0.5mm changes.
1998 ZX6R R.I.P.
2011 ZX10R
BladeBoy
Post by BladeBoy »
Dave, do you have extra fuel line to remote the tank ?
dave#3
Post by dave#3 »
Awesome, thanks Aus ... I think we'll start with the float levels and a carb balance first thing tomorrow.
give your needle/seats a good tub as well, if you are doing the float heights first thing, it would be nice to know that the needle/seats are clean and in good nick.
dave#3
Post by dave#3 »
Mark wrote:Dave, do you have extra fuel line to remote the tank ?
I suspect I've got enough to knock something up, otherwise I'll duck down to Repco in the morning and grab something (unless you've already got something sorted out ?)
dave#3
Post by dave#3 »
Gosling1 wrote:give your needle/seats a good tub as well, if you are doing the float heights first thing, it would be nice to know that the needle/seats are clean and in good nick.
Will do, thanks IvePulledDownAndRebuiltAlmostEverythingDave, your wisdom is appreciated.
Now I've just got to stop drinking, go to bed, and see what tomorrow brings :D
Aussie Ninja
If it is the float I think 0.5 - 1mm should see you right. If you go too rich you'll know it by the big dooee spot about 3-4k. :wink:
1998 ZX6R R.I.P.
2011 ZX10R
icebreaker
State: Tasmania
Post by icebreaker »
dave#3 wrote:Awesome, thanks Aus ... I think we'll start with the float levels and a carb balance first thing tomorrow.
Feel like doing mine while your at it Dave ;)
Mine hasn't been done since the 18K service, and she's on about 47K now.
Ducati Monster S2R1000
