best way bust open fuel cap lock?? *solved*
SocialSecurity
Post by SocialSecurity »
.... do you know what a new set of locks and HISS system for a 1000RR is worth? :? id say it would be much the same with a ZX6R
YAPPA
Post by YAPPA »
push the fugger out into the middle of the yard, put ya helmet & leathers on & strike up the oxy set......this method is guaranteed to get the bastard open quick as a flash.....or is that get the bastard open with a big flash :? ......maybe stick with the hammer & screwdriver :lol:
Frank
Post by Frank »
I have the perfect can opener, Homer Simpson style qleft6.gif , One shot will remove the lock, might need to patch up the big hole in the bottom of the tank though. :twisted:
GO THE BLUES
Life time member of PETA:-
Member of SRT
1998 Kawasaki ZX9R Track Bike
2014 Nissan Navara
mate make the scredriver fit.
SocialSecurity wrote:.... do you know what a new set of locks and HISS system for a 1000RR is worth? :? id say it would be much the same with a ZX6R
This model of the ZX6R doesnt have electronic protection...
As for removing the whole fuel cap assembly, that doesnt work if the cap is still locked, because you cant removie it while it is closed (happened to my on my honda)...
Drilling it out may cause problems because you wouldnt be able to close it any more...
On the good side, if you drill it out, you can remove the whole thing and replace it with one from the wreckers (with a key too)...
mikk
Post by mikk »
that lockpicking page is quite good.
thanks for starting me on a life of crime :D
varden
Post by varden »
maybe if i drilled a three holes along the length of the key hole so i could get a decent size screwdriver in there??
seany
Post by seany »
DO NOT use an angle grinder. :shock:
:lol: :lol: :lol:
Little black duck upsets easily. Reassure and give beer.
SocialSecurity
why not just knock (not drill) a small hole in the top of the tank so you can put petrol in it till you work out what you wanna do with the lock... put a cork in it to seal it :lol:
varden
Post by varden »
its done!!!
3mm drill bit
Black and decker cordless drill
Flat head screwdriver with square shaft
6 inch shifter
step one: drill three holes along the key slot
step two: insert screwdriver
step three: apply shifter to shaft of screwdriver
step four: turn clockwise while maintaining downward pressure on the screwdriver.
step five: listen for crunch of lock giving up
step six: lift up cap and take assembly off tank
step seven: bang metal filings out on ground.
step eight: refit cap
step nine: twist lock open and closed a dozen times to ensure its not binding up.
HemiDuty
Post by HemiDuty »
Good stuff. Now filler-up, there's tracks a-waiting!!!
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
Barrabob
msn
Post by Barrabob »
hey drim is msn working.
YAPPA
Post by YAPPA »
Here's one I prepared earlier........
First with new filler
YAPPA
Post by YAPPA »
New non lockable cap....It's even colour coded :lol: No key....no worries
colour coded cap
colour coded cap
kellz
Post by kellz »
very funny
