http://www.toymods.net/forums/showthread.php?t=87 <-
"you cannot dim LED's PROPERLY by reducing the voltage driving them. They will dim possibly ~5-10%, and then they'll just shut down. To properly dim an LED you have to vary the current to the LED whilst maintiaining a voltage just a little higher than the forward bias voltage (usually the rated as "typical operating voltage").
To do this you need a simple transistor circuit using a very common 30c transistor and suitable resistors and a trimpot to vary current. I have done it before, but it's buried in the "celica box" somewhere....
in most cases, running your typical 3.0-4.0V operating voltage LED at around 20-50mA from your car you should use approx 570 ohm resistor."
Electronics guru required - dull down my LED tail lights
Maty10
Ahhh stevew_zzrbet me to it!
You can't vary the brightness of a LED by changing its voltage, that's a design goal so they can work on digital voltages with noise, etc.
Hence why they are used in flashlights, batteries can go flat, but you still get the same colour and (near) strength light. Unlike incandenct globes that go yellow and dimmer.
To vary a LEDs brightness you have to switch them on and off really really fast (hence the mention of a transistor).
- Stereo
Do LED's generate any heat? I thought that they didnt... and if not... why not cover the rear tail light with a perferated film that matches the paintwork..dave#3 wrote:Anyone want to buy four LED tail-lights ? Hardly used, one female owner
This is all getting way too hard
The tail light will almost disapear until you turn the lights on... and they will be dimmed a whole bunch... but when you are braking they will be quite bright...
Or... how about having only ONE led? They are after all twice as bright, you would need to centre the bulb somehow if possible...
stevew_zzr
