it is possible that the rear sprocket has not worn much , even after 17 years.Saki wrote:the rear wheel sprockets actually looks fine, i have given it a good spin around and a close looking at and it seems fine from my judgement...
The trick is to look for any obvious signs of *scalloping* of the sprocket teeth. The semi-circle between each sprocket tooth is perfectly symetrical on a new sprocket, so if your rear sprocket still looks like this, it *may* not need to be replaced.
I have worn chains out to the point that they jump sprocket teeth (as have probably a few other people out there
If your rear sprocket shows any sign of wear, even a little bit, you can almost *guarantee* that the front sprocket is also stuffed, so better to replace the lot........the quickest way to wear out a new chain is to use it on old sprockets......
