SV650 won't start
ive never had it happen, but one thing that shits me off is when a shop slaps their sticker on your car/bike without checking with you if they can.
if it was a honda I would say check the regulator rectifyer.... since the ones on hondas tend to go belly up and then your bike wont start...
Stereo wrote:if it was a honda I would say check the regulator rectifyer.... since the ones on hondas tend to go belly up and then your bike wont start...
isnt it a common problem with plenty of bike :?:
Yup, most of them being hondas :)
fair enough :D
diesel
Team Piss Head
Team Piss Head
Post by diesel »
turned out to be a real tricky mother.
you need two things, spark and fuel.
now when we ripped out the plugs, they were wet, so i knew we were getting fuel. so cleaned them up, tested for spark, yep. wacked em back in and it still wouldn't run. quick call to rossi and he informs me sometimes u'll get spark when u test the plugs, but they'll fail under compression. so down to brighton kwak for some new plugs. shit they're closed. oh well we'll go in next door to brighton bikes and bits. top service. not only did they provide us with plugs, but also a quick run down on how to drain the barrell if new plugs didn't work.
but new plugs did the trick. i took it for a quick spin and it's runnin well.
ro-dogg send his thanks for the advice and help from everyone here.
ZZRCHIKKY
Post by ZZRCHIKKY »
i know exactaly whats wrong with it . . .
. . . its a suzuki :D:P
diesel
Team Piss Head
Team Piss Head
Post by diesel »
hit the nail on the head with that one chikky.
and to make things worse. cos it's a v-twin, you gotta remove the top fairings and radiator to get at the front plug. far more effort than it should require
Duane
Post by Duane »
diesel wrote:hit the nail on the head with that one chikky.
ahahhaha
i know how that worked
the TL was amazing
had to remove everything and unbolt half the radiator and use it like door to get to the front plug
www.bromancer.com.au
