Lube V's Wax ?
Toby
Re: Lube V's Wax ?
I've tried most of them and Belray Super Clean Chain wax is the lube of choice. No fling, No build up, and goes on white so u can see haow much u have applied.
Supa stuff.
Supa stuff.
GSXR1000 White K9
Rusty
Re: Lube V's Wax ?
'Nother vote for Motorex. Good stuff.
- ZX-10R_04
- State: Tasmania
Re: Lube V's Wax ?
hoffy wrote:Does Kero come in a can, like to spray on ?
04 ZX10R & 08 ZX10R
04 ZX10R & 08 ZX10R
- Smitty
Re: Lube V's Wax ?
one tip re chain lube/wax/oil/whatever
please put it on the INSIDE of the chain
you know..the bit that touchs the cogs/gears
this helps you see
putting it on the OUTSIDE of the chain means
little lubrication and lots of chain lube being flung off
don't larf..I know those who are outside lubers
this helps you see
Re: Lube V's Wax ?
Smitty wrote:don't larf..I know those who are outside lubers![]()
Re: Lube V's Wax ?
its OK mate, we know you have been an 'inside' luber from way back...............Smitty wrote:.....don't larf..I know those who are outside lubers.........
- Possum
- State: Western Australia
Re: Lube V's Wax ?
While your asking... better check if its oil or water based!mick_dundee wrote:Well damn I was thinking bikini linesPossum wrote:Is lube better than wax ? Why why not?
Yes we are talking chains![]()
Poss
I believe Stace has a preferre bum lube, not sure if he uses it on the chain as well, have to ask Groggles I guess
- Smitty
Re: Lube V's Wax ?
Possum wrote:[While your asking... better check if its oil or water based!
roflmao.......
- ZXRobyn
Re: Lube V's Wax ?
mmm yeh, I bought a can from bike shop in Albury late last year due to limited choice, and not impressed to say the leasT!! I thought it was crap.Slow and wobbly wrote: I once wrote an e-mail to Shell regarding the Shell Advance chain lube as a letter of complaint stating that I was not happy with their product in that more of it remained upon my rims, ducktail and pants than on the chain.
Their response was " We are sorry that you do not find our product to be adequate to your needs and we hope that one day in the future you will again try our products again as we are constantly refining them. We thank you for your comments but we have trialled and evaluated this product in the marketplace and attained satisfactory results"
So apparently the common motorcyclist they evaluated was happy to have to clean all this muck off they're bike and re-apply it regularly.
previous to that I used silkolene; it sprays on white, and i thought it seemed to set better than others, with little 'fling off'? bike shop I went to last week didn't have it tho, so I bought can of Motul, as it seems to be a popular choice used by many.
Suitable for on and off-road use, Silkolene Chain Lube is a semi- synthetic motorcycle chain lubricant. Chain Lube penetrates to inner rollers and pins and resists high speed fling off providing long-term lubrication and keeping your bike cleaner. Chain and sprocket life benefit from outstanding anti-wear and anti-corrosion properties..... hey, sounds like I was prepped for the trip to WSB and all, lmao.
Anyway, just thought I'd post my 2c (gotta get rid of this 'newbie' tag somehow)
- Silkolene.jpg (7.8 KiB) Viewed 3126 times
HCST #1
- Possum
Re: Lube V's Wax ?
Thanks ZXRobyn for your "2c worth" its good to have options tried and true from fellow riders...
Re: your newbie status you should post a blurb about yourself in intro's.... get to know a few people..
Cheers Poss
Cheers Poss
SnypR
Re: Lube V's Wax ?
l use the Fuchs Silkolene lube as well, no fling and seems to stay lubed for a long time.
- Magpain
Re: Lube V's Wax ?
Today I just lubed my chain by spraying it with engine degresser then hosed it down and dryed it with rag, may off used some WD-40.. and then sprayed heaps of Motul chain lube (Road) on.. It all got on my wheel and tire but cleaned it off.. Have I done wrong??? It was my first time.(newb alert) Sounds like I should get some of thus kero type product and maybe one of those lamps to. REally wanted WAX just thought lube was the same but seems abit straight edge to me. Plus does your head in spraying all that stuff on spechially when it blows back in your face and burns you nostrals///
- Big Daddy
- State: Overseas
Re: Lube V's Wax ?
wax is for candles, and just as it accumalates in runny little piles after melting thats what happens when its used on a chain just not as severe and a royal beiotch to clean off after several applications.
BD
BD
Re: Lube V's Wax ?
The degreaser has slovents in it that are no good for the orings in your chain.... it seeps past the orings & disolves the lube under contained underMagpain wrote:Today I just lubed my chain by spraying it with engine degresser then hosed it down and dryed it with rag,
