Quickshifter - anyone want one.???
Re: Quickshifter - anyone want one.???
MAXUMIS wrote: i believe you mate i guese i might have been miss lead at one stage sorry for the inconveniance!
No, thats fine, thanks for bringing it up, you may have not needed anything, but at least we know that some bikes do. (better looking into this than watching that stupid football game :oops: )
We didn't know Blurrs 08 zx10r needed the QEM or Ign module to get his to work.. Explains a few things now, we thought it was a dud.
Its a bugger Wattie broke it as would work on his bike (07 zx10r) probly Blurs now too. ;)
Gos, yes you need one... even its just to see if an ignition module is needed.. :-)
MAXUMIS
Post by MAXUMIS »
its been a great talk mate much appreciated :D :kuda:
life starts at 200 kph!
by the way this is the same module that i have on my bike to get the auto tune working
Baddie
Post by Baddie »
Blurr wrote:by the way this is the same module that i have on my bike to get the auto tune working
How is it the same???? arent you running PCV?
http://superbikesource.com.au/
For aftermarket racing products, from Annitori Quickshifters to Race fairings.
http://tarmactalk.com/forum/forum.php
still need an ignition module
Baddie
Post by Baddie »
Ignition module or QEM?
MAXUMIS
Post by MAXUMIS »
ive learnt a lot tonight.thanks fella's :D
pittster
Post by pittster »
Not really adding anything here but just wanted to be in the cool thread anyway yes the 08 zx10+ have 8 injectors, Primary's are in the normal spots, Secondarys are in the top of the airbox pointing straight down the Throttle bodies. As far as i know PC3 or PCIII or PC USB don't control the secondarys i'm not sure if even a PC5 controls them ? They only add additional fuel, not like a Aprillia RSV4 Factory for e.g. which uses one set for below a certain rev range and the other for higher revs.
As per pic injector can be seen top right.
Kawawog
Post by Kawawog »
pittster wrote:Not really adding anything here but just wanted to be in the cool thread anyway yes the 08 zx10+ have 8 injectors, Primary's are in the normal spots, Secondarys are in the top of the airbox pointing straight down the Throttle bodies. As far as i know PC3 or PCIII or PC USB don't control the secondarys i'm not sure if even a PC5 controls them ? They only add additional fuel, not like a Aprillia RSV4 Factory for e.g. which uses one set for below a certain rev range and the other for higher revs.
The PCV doesnt control the secondary injectors, only the primaries.. You need to buy a SFM(secondary fuel module add on) to have any adjustment of those ;)
OK I sent Power Commander an e-mail and got the following response.
For the zx12r
The ZX12 only has 4 injectors; and therefore the Power Commander can run a Quickshifter by itself. No QEM or Ignition module necessary.
For the 08 + zx10r (or 09 + zx6r - anything with 8 injectors) to run a quickshifter.
Running a PC3 you need the ignition module, the QEM is not compatable with the PC3
Running a PC5 you need to use either the QEM or Ignition module.
04 to 07 zx10rs, 03 to 08 zx6rs, zx12rs, z1000's etc using a PC3 its just a plug and play set up nothing else required...
marksesh
Post by marksesh »
I want on but what the hell does it do???
Team 4 minutes behind everyone else.
marksesh wrote:I want on but what the hell does it do???
Let's you change gears without releasing the accelerator.
marksesh
Post by marksesh »
Umm I have enough trouble dont think this would be much good for me. Cant bowl cant ride!
Supafrog
Post by Supafrog »
MadKaw™ wrote:OK I sent Power Commander an e-mail and got the following response.
For the zx12r
Yay for only having 4 injectors! When i can actually utilise the power, it wont be as expesive to get one of these quickshifters! :D
MAXUMIS
Post by MAXUMIS »
For the zx12r
thanks for the input!i
