KAWASAKI S2 350 RESTORATION
kawadave
Re: KAWASAKI S2 350 RESTORATION
Post by kawadave »
Excellent amr...looks tops,let the fun begin. :kuda:
2013 Motogp tipping champ.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
frame lookin' good :kuda:
TITANIUMBULLET
Post by TITANIUMBULLET »
thanks dave and gos. the engine is stripped and will be blasted at my mates engineering shop and hopefully put back together by me properly in a couple of weeks ! :oops: :oops: pics to folow :P
2019 multi 1260 ENDUROTOURER
1972 H2 750 BLUE PRIZED POSSESION THE KING!
1974 H1E GREEN CLASSIC
3 X 72 s2 350 ALL RED
1 X 73 S2 350 BLUE
08 ZX10R WEAPON SOLD08
klx450r bush basher(sold)
05 zx10r titanium(gone)
2 X 06 ZX10r (gone)
07 zx10r track bike(gone)
06 r6 yammy track bike(gone)
TITANIUMBULLET
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
TITANIUMBULLET wrote:....thanks dave and gos. the engine is stripped and will be blasted at my mates engineering shop and hopefully put back together by me properly in a couple of weeks ! :oops: :oops: pics to folow :P...
sounds good - when you get the cases back, give them a really good blast with the air duster. Then do it again. And once more for good luck ;) some lashing of spray-on carbie cleaner through all the oil orifices is also a good idea. You wanna make sure all the blasting medium is cleaned right out.
TITANIUMBULLET
ok will do thanks!
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
TITANIUMBULLET
sandblasting is hard work but well worth the effort!!!
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
make sure you wear latex gloves whenever working on those cases now. Bare sandblasted ally is a magnet for oil, and once you stain a sandblasted surface - it stays stained. Might be worth exploring options for some type of clear coating for these while they are in really good clean condition.
TITANIUMBULLET
Ok good advice, i noticed i left a few fingerprints haha
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
BrettZZR
Bike: ZZR1100
Post by BrettZZR »
I did the opposite - I covered them with oil, working it into all the ports and nooks and crannies and then washed them with degreaser and a high pressure gun. Best way to make sure you get rid of all the grit, and after that they are immune to oily fingers...
(-8
BrettZZR wrote:......I did the opposite - I covered them with oil, working it into all the ports and nooks and crannies and then washed them with degreaser and a high pressure gun. Best way to make sure you get rid of all the grit, and after that they are immune to oily fingers.....
what sort of cases did you do this on mate ?
BrettZZR
Bike: ZZR1100
Post by BrettZZR »
Various bike engine bits (CD125S; CB550; CB750F) and aluminium car engine blocks & heads (D16A8 x3; B18C; B20Z x2 ;B20B)
When I assemble an engine I use HEAPS of assembly lube and oil everything liberally - there is simply no way of not touching the casing outers with oily fingers.
If you are SURE there is no grit left in it anywhere, then skip the high-pressure wash step and just use diesel. Don't have to wash it off until after the bike is assembled.
(-B
davo231481
Post by davo231481 »
Gosling1 wrote:
TITANIUMBULLET wrote:.....i think i'm going to clean it up and take the risk. it doesn't look too bad......
Col Linney was a z9 legend, but he is long gone unfortunately......
Looking forward to seeing this rig on the road :kuda:
as in 10/ 10ths at el toro estate liverpool. whatever happened to him I wonder?
BrettZZR wrote:Various bike engine bits (CD125S; CB550; CB750F) and aluminium car engine blocks & heads (D16A8 x3; B18C; B20Z x2 ;B20B)
(-B
hmmm OK - not sure about the ally content of the CB motors, I know that the early kwakka triples are really prone to oil-print contamination
davo231481 wrote:......as in 10/ 10ths at el toro estate liverpool. whatever happened to him I wonder?......
Yep, thats the one. He retired maybe 10 years ago or more now, moved up to Qld. One of my mates in Sydney had a motor built by him just before he pulled the pin. The guy knew kwakka motors better than just about anybody....
:cool:
davo231481
he was red hot on suzukis too. most of his machining was done inhouse as well.
