Removing Baffles
ant
Removing Baffles
Post by ant »
Hi All,
Want to remove the baffles from my stock Z750 pipe.
Is this hard to do?. Is it simply a case of drilling the pop rivets off the end of the pipe, and removing the baffles.
How are the baffles packed?, do they just slide out?.
I got a quote for $240 to get this done at a shop, and no way in hell am I paying that.
R.I.P Craig William Park. aka 'Skippy'. You may now be resting, but rest assure you will NEVER be forgotten.
16/8/1984 - 10/9/2005
'Born To Ride, Ride Till Die', 'Up On 1', 'Standups 4 Life', '57NTS'
Mate get an aftermarket pipe..............................
Keep your original, that way if you get pinged you can put the original back on to pass inspection.
ant
Post by ant »
I was of the impression it wasn't that hard to remove the baffles, that's why I wouldn't mind doing that until I get an aftermarket pipe....
Gotta get me some new gear before pipe.
What sort of gear do you need?
ant
Post by ant »
In the following order:
new tyres
service
replace existing jacket with new leather Jacket/new gloves
pipe/belly pan.
I've got a similar list but rego is due next month so that gets priority :(
Good luck with getting everything....
ant
Post by ant »
robracer wrote:I've got a similar list but rego is due next month so that gets priority :(
Oh yeh.
List edited then
Car rego
Bike rego
new tyres
service
pipe/belly pan.
:lol: :lol: :lol: damn thats gotta hurt the back pocket
Nanna10r
Post by Nanna10r »
OEM Baffles can be Pretty Tricky to take out as they normally are spot welded into the outter sleeve with Partitions separting compartments.
After market pipes on the other hand are usually a "pieceofpoop" to muck with as they only have a single pipe inside as opposed to a few like the OEM units
hth.
Duane
Post by Duane »
1. take 1 large metal rod (preferably with a pointed end)
2. place pointy end inside muffler
3. take 1 large metal mallet or hammer.
4. whack the absolute crap out of the metal rod using the mallet or hammer.
5. Baffles been removed.
www.bromancer.com.au
FrogZ
Post by FrogZ »
ant, befoire doing as Duane said (he is right) maybe you should read Tanya's baffles removed thread.
You are going to make the fueling go to shit.
Hope you have a big selection of needles, a dyno and a LOT of time on your hands dude.....
OOPS Z750 so assume late model & EFI.
In THIS case you ONLY need PCIII, Dyno and good operator.....
If it only makes noise and no power, whats the point ??
Is it really worth the hassle for the noise ?
(Says he of open Micron fame....) :twisted:
Froggies right..............
and so is Mr D :D
Duane
Post by Duane »
hehe :) I got a bit carried away when i did it to my two fiddy, after whacking the crap out of it, went back to my mates workshop, cut off the muffler, cut off both ends, removed the whole frikken lot, welded it back together wahlaa magic, straight through can.
Sounded like a lawnmower on steriods.
javaman
Bike: GPz900
Post by javaman »
Read the "aftermath of baffle removed" from tanya.
-ariel circa 2007
http://GPZninja.blogspot.com/
Duane
Post by Duane »
Despite this fi problems.
It's worth doing if you want the sound without the $$$ spent.
Power commander is alot cheaper than
A exhaust can and power commander or full system and power commander :)
