2000 zx6r. When the engine is hot it sometimes stutter and dies. Wait few minutes and then ok again.
Thinking it may be heat related -- but even when it goes to higher temperatures it's ok ...
not sure where to start looking... maybe connections, grounds?
Any idea ?
When hot the bike sometimes died
- javaman
- Bike: GPz900
http://GPZninja.blogspot.com/
wet4uracing
stutter
yep they used to do that. if you were back in 2000 now u could ride it in to a green dealer and they wood fit a new set of carbs FOC and it wood be new again, but alas its not and you cant, so best you get a guru to strip and check them carbs.
- T1 get off.jpg (111.27 KiB) Viewed 1794 times
Close but not quite correct.Stereo wrote:...Remember the fundamental of a combustion engine... to run it needs 3 things
1. Air
2. Fuel
3. Spark
The 3 things are : 1 - Fuel, 2 - Spark, 3 - Compression.
Of these 3, the most common cause of all problems is *spark* (electrical), followed by *fuel* (carbies, tap, tank), then finally compression (pistons, rings, valves, etc).
I would start with electrical stuff first, its always worth checking connections, voltages, etc, before you start ripping carbies apart...
Good luck mate.
- Sulli
Re: When hot the bike sometimes died
Same symptoms for me sporadic engine failure leave it 5 minutes it would startjavaman wrote:2000 zx6r. When the engine is hot it sometimes stutter and dies. Wait few minutes and then ok again.
Any idea ?
My issue was the fuel pump seizing and hard to detect as it did not happen often when it cooled down ok again
Worst part is if it is the fuel pump you can destroy a couple of batteries as the curcuit only completes on the starter turning over or the motor running
( so it does not prime prior to turning the ignition on) Does that make sense to you??
- javaman
- Bike: GPz900
Thanks all for the diagnostics ... I think I found the problem. The stator was fried, alas no charge to the battery (or very little -- enough to run). During hot day the fan activated and it drained the battery. Being hot, there is no charge left to power the bike.
When cooled down, the battery is back to normal.
I have fixed the stator and electrical system is stable now (see "stator resistance") thread.
Thanks again
Thanks again
