another oil Q.
rotaboy
another oil Q.
Post by rotaboy »
hi guys
my bike is due for a service but with money and christmas etc i was thinking of just doing the oil change my self as its not a mojor service this time round.
was going to get some motul oil and wondering if any 1 has a preference as to what type
or what i should get
also is there anything else u guys do on the intermiate service
justin
How many k's has your bike done ? Do you know what the last oil was ?
Other things on a minor service are air-filter clean / change if required, oil filter change, check brake pads, chain tension, all lights etc.
rotaboy
Post by rotaboy »
its the 18k service and not sure what oil went into it b4 as it was services from the shop i brought it from just b4 i brought it
Nanna10r
Post by Nanna10r »
Go See Mick at MTM Goodna, I get my Fuchs silkalene there. Easy as dropping the oil N filter out.
Post by mick_dundee »
Motul 5100 seems to be the shit everyone raves about FWIW, not used it myself but due for an oil change in 2000k or so so might give it a run then.
rotaboy wrote:its the 18k service and not sure what oil went into it b4 as it was services from the shop i brought it from just b4 i brought it
OK - use Motul 5100 and change the oil filter. Clean the air-filter, and if its really dirty, then throw some $$$ into a set of BMC filters.
rotaboy
Post by rotaboy »
thanks for the advise think i may just be going to the shop tommorow... would the bmc filter mess with the computer/ air fuel ratios much (i also have a yoshi slip on)
Some people will say yes, some will say no. I belong to the latter ..... it all depends on how recent your model is, and how the ECU will deal with a *slightly* more free-flowing air filter.
I think you will find it runs just fine, the main benefit with BMC's, K&N's etc, is that they can be cleaned as re-used for *ages*, unlike the stock paper filters.
Talk to the shop dudes, but with just a can and a filter, I think a PCIII would be uneccesary...........if you go a full system, then its time to put one on.
rotaboy
Post by rotaboy »
cheers mate
will look into the filter as well
and its a 2003 6r
