Bike not starting
- Duane
Bike not starting
Hi
I'm having some trouble starting my bike, Which way should the red switch be turned, also do I turn the key to lock or ignition. I'm not to sure.
I keep turning the key but the damn thing wont start, and what the hell is the green light?? I think I have a oil problem too because when I turn it too ignition (which doesnt start it, ?!?!) the oil light comes on, I have oil though.
I didnt have enough first time, so was i Ok in using sunflower oil? i figured if it's good enough for my insides, its okay for my kwaka??!
Also, my chain has this greasy stuff on it, is that normal?
www.bromancer.com.au
The number 1 reason most bikes won't start is lack of air in the tyres , make sure you check the pressure but if it's not that it will probably just be that you have the wrong type of air in them so you'll have to take it to a tyre shop and ask them for ( and be very specific ) motorcycle tyre air as the car is really bad for bikes
- Duane
Oh no, I pumped my tyres up last time i was out at a petrol station, A car used it before i did so maybe i got the car tyre air?!?!
Speaking of which, Last time i washed my bike I used car wash soap, is this okay, or is this also likely to not let my bike start?
I'm really worried now, I've got so many things I may have done to cause this
By the sounds of it I'd say your bikes buggered with all the car products you've used on it tsk tsk time to trade up I reckon , mind you the sunflower oil was okDuane wrote:Oh no, I pumped my tyres up last time i was out at a petrol station, A car used it before i did so maybe i got the car tyre air?!?!
There's your problem then. You probably got car fuel in it. Drain the tank and let it dry out completely before you fill it with Red Bull.Duane wrote:Oh no, I pumped my tyres up last time i was out at a petrol station, A car used it before i did so maybe i got the car tyre air?!?!
- Duane
it was a mobil, only reason i stopped there is because they had 2 bottles of redbull for sale for $5 - i didnt use the petrol - gsst. Geeze you people think im that dumb as to use car petrol!??!Daisy wrote:There's your problem then. You probably got car fuel in it. Drain the tank and let it dry out completely before you fill it with Red Bull.Duane wrote:Oh no, I pumped my tyres up last time i was out at a petrol station, A car used it before i did so maybe i got the car tyre air?!?!
nah, its the valves...
you need to spray lube on them and start it.
its probable caused from when you washed it, water got into the valves and seized them up.
thats what the well trained Kwak mechanics told Tanya
