Just got a 35 Amp 6 wire rectifier from EBay, to replace the (Second) shite old stock one on my ZXR250.
Looks good, was just wondering though :
There are 6 wires, as follows : 3 for the alternator (Doesn't matter what order they get plugged in, as the rectifier (Diode Bridge), sorts out the AC input, and outputs a constant DC charge, Am I right ??)
2 more wires, 1 for the Battery +, the other for -
Then the final wire, which I am told is for the " Remote " - Is this for a power source when the ignition is turned to the " Accessory" position ?
Would the Remote wire need to be wired in, or can this be left alone, would the rectifier run anyway (I think it would ....??)
All I need to do is solder the plug from the old rectifier to the new one - I got a cool gas powered soldering iron and some heat shrink from Dick Smith today, should end up being a pretty tidy job.
Any ideas on the remote wire, or other tips, would be greatly appreciated.
Maybe then I won't have to push start the bugger twice a day, like for the last MONTH !!
